Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 05-04-2003, 10:11 PM
Kill4A911's Avatar
Kill4A911 Kill4A911 is offline
Send a message via AIM to Kill4A911
cool, im looking at a nitrous express wet fogger
Civic:selling the D16Z6 getting ready for a B16 turbo
240Z:was thinking about a VG30DETT but am now looking at a V8
Old 05-05-2003, 09:20 PM
ric's Avatar
ric ric is offline
Send a message via AIM to ric
do any of younz have a turbo or know anyone with one?
h series motors have nikasil coated sleeve's, they are much stronger then d or b sleeves. thier problem is weak ring lands that sit way to high on the piston. the solution...getting forged pistons. well it doesnt work well because forged pistons score nikasil and you blow your motor, so you need to get pistons coated or you need it resleeved
as for b series motors my freind chris runs 10psi on a stock b16. most of the guys at hybrid dynamics (a shop around here) run about 8-14 on stock gsr's and one guys runs that on a type r and all with simple fmu's except chris who has the vafc fix.
and d series motors can hold it too, our boy jim ran 10 psi unintercooled with a greddy kit for months till he swapped in an h22, not to mention countless kids we meet up with every weekend from around the city that run 10psi+ on generally stock motors.
honda motors can handle the boost, they just like to be tuned right, plain and simple.
Old 05-06-2003, 04:41 AM
MARKUSIUDIUS MARKUSIUDIUS is offline
10 psi on a stock h22a is asking for trouble, as i know. I ran my car fine on 8psi with standard internals but as soon as i went up to 10psi it threw a rod out the block. This was whilst it was on a dyno getting tuned for the extra pounds.
If you want to make good cheap power out of a h22a i recomend you drop in a thicker head gasket and run no more than 8psi, it with 98ron fuel will run forever.
All the best :flash:
1994 2.2lt Jap import Vtec, Blown with a 1GGZE charger 300Hp or 220+kw
Malpassi Reg, 500 injector, Unichip piggyback management system, Top gun leads, Map controller, Vtec controller, Custom FM Cooler, Custom fast flow exhaust and weight reduced (2640pds)
Old 05-06-2003, 07:24 AM
grrrr grrrr is offline
ok i just want to say one thing and if im wrong... then im wrong but not all h series suck for turbocharging. The H23A1 has a 9:8:1 compression ratio and is closed decked. doesnt that mean anything?
