Go Back   Automotive Forums Car Chat > Honda > Integra
Old 05-02-2003, 09:00 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
Originally posted by RedNeck383
Cause its british.. haha....
Nope, its cause there was dirt in the tank, me and my dad rigged it up ourselves. Heres a pic of the engine, you can see em on the left side by the carbs.
and a pic of the car itself
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 05-02-2003, 09:30 PM
kagegod kagegod is offline
PWMAN is right. higher octane gas does NOT give you more power. It's like a placebo really, only makes you THINK that it does. Now if you had a turbo, supercharger, nitrous, or changed the compression of your engine it would be justified to get the top end octane as it will prevent knock - this is done by additives to the fuel to resist knocking. IF you are noticing improved gas mileage or improved performance, that is typically an indication that your car needs a tune-up, and a tune-up is cheaper than paying all the extra money for the "performance" you'll see. Unless, like stated above, you're running turbo, nitrous, supercharger, or changed engine compression - it's a waste of money to buy higher octane gas than what the manual recommends.:o
Old 05-04-2003, 02:08 PM
PWMAN's Avatar
PWMAN PWMAN is offline
Thanks
Old 05-08-2003, 12:23 AM
90gs's Avatar
90gs 90gs is offline
Send a message via ICQ to 90gs
chevron has techron.. intake valve cleaners.
Old 05-09-2003, 07:39 PM
90gs's Avatar
wow ... i mixed 4 gallons 89 octane with 4 gallons 91 octane and it owns! i broke LOOSE shifting into 2nd yesterday, ive only been able to chirp it like once before but i sat there and span for like 3 seconds... those of you with 2nd gen integras know its damn near impossible without clutch upgrades or FI
Old 05-09-2003, 09:04 PM
PWMAN's Avatar
Ummm, thats not the reason it spun, I can tell you that much. Must have just been the surface you were on happen to be slick.
I used to own the same car you have, a 90 GS teg, and I could smoke the tires through second gear on the stock clutch.
I sold my teg though:cry:
But I still have a 88 RS and a 2000 LS
Old 05-10-2003, 03:14 PM
90gs's Avatar
i think it is.... cuz i could spin thru 2nd gear all i wanted when i had the mix, but after driving for a while the tank ran empty so i filled up with 91 and i cant do it anymore.. i did it on warm pavement and cold pavement, could spin on either when i had the 90 octane mix
Old 05-10-2003, 04:11 PM
PWMAN's Avatar
Umm, do you want to restate that? you mean filled up with 89 or 87? Cuz 91 is high test for you right?
Old 05-12-2003, 12:52 AM
90gs's Avatar
no i filled up with 91... not 87 or 89, i dunno why it works better with 90 than 87, 89, or 91... works even better than 91 with octane booster
Old 05-12-2003, 07:34 PM
PWMAN's Avatar
Was the 90 octane from a different gas station?
Old 05-13-2003, 12:33 AM
90gs's Avatar
all chevron.
i could spin 2nd with the mix of 89 and 91, i cant even chirp 2nd with 91. i ran empty on the 91 octane and i filled up with half and half 89 and 91 and i can spin 2nd again..
Old 05-13-2003, 08:26 PM
PWMAN's Avatar
all chevron.
Thats crazy. your car is f'd up!
Old 05-13-2003, 09:29 PM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
this thread is f'd up is how it should go :hehehe:
read ur manual, unless u have higher compression pistons or some internal mod's, u don't need anything but wut the good ol' ppl at honda say. end of thread.
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 05-13-2003, 09:54 PM
Melt's Avatar
yup
AF Bay Area Crew
Old 05-14-2003, 06:16 PM
90gs's Avatar
manual says "Use Higher Than 86 Octane" which basically means anything at any gas station that isnt diesel but my car runs like ASS on 87 octante plus that crap clogs your fuel filter and fuel injectors bad..
