Old 06-26-2020, 01:18 PM
Capri-Schorsch's Avatar
Capri-Schorsch Capri-Schorsch is offline
Re: Zakspeed Turbo Capri 1/12 Scratch
Next update on Capri.
The dashboard and parts of the cage are made.
The cage only made a few problems in terms of impressions. After a night of thinking about it, I found the negative form with which I can take it.
I'm just going to make the two sides in resin, you can just make crossbars out of round tubes.
greetings Christian
Resin Kits and Parts for sale ! New Updates on my website.
Old 06-30-2020, 01:29 PM
So the kit is now ready.
I created all the silicone molds and added a few small parts that weren't planned yet.
But was so "in the flow" that something was added.
Here is an overview of all parts included in the kit:
The roll cage consists of only two side parts, the cross braces can be easily added by the inclined buyer himself from plastic tubes.
I made a few small parts for the trunk, but to fill it properly you have to scratch a few parts yourself.
Then there were pedals and I "bent" two coolers in front of the rear wheels.
I also made an exhaust.
Unfortunately, the dashboard was not quite as hoped. I took the original ferrules and it looked really good. Unfortunately, these sleeves are so thin that they cannot be molded properly. Too bad!
Either drill holes or install them with ferrules.
That's it for now.
Now I have to see if everything fits so far.
Oh yes, there should also be a motor kit with gearbox, but I'm honest, I have already announced this with other buildings and did not pull through in the end.
After such a long construction period, you will be happy to have everything ready at some point and the motivation to make more shapes has dropped significantly.
greetings Christian
Old 07-05-2020, 09:59 AM
nugundam93 nugundam93 is offline
Blarg! Wort Wort Wort!
love the progress!
olly olly oxen free
The Following User Says Thank You to nugundam93 For This Useful Post:
Capri-Schorsch (07-22-2020)
  #229
Old 07-22-2020, 01:25 PM
Small update.
The capri was stripped of his hoods and a door.
It was pretty easy.
The Würth Decals with printed discs are already there.
greetings Christian
Old 02-02-2021, 01:56 PM
My model-making mojo is back and I continued building on the Capri right away.
The door has found its fastening.
I built the cage from the resin sides together with aluminum pipes.
I worked the rims from the back so far that you can see through the grille.
The vehicle height has now been determined.
Now I go to the subtleties like closing small holes before I start installing the motor-gearbox dummy.
I hope that the updates will follow a little faster because I now have the decals for the white Würth, the black D&W and the Liqui Moly Capri here.
So I have to build the Capri 3 times.
best regards
Christian
Old 02-04-2021, 07:18 AM
chris24 chris24 is offline
Good to see you back
The Following User Says Thank You to chris24 For This Useful Post:
Capri-Schorsch (02-05-2021)
  #232
Old 02-05-2021, 12:49 PM
lovegt40's Avatar
lovegt40 lovegt40 is offline
ItaloSvensk
grande Christian. masterpiece as usual
Paolo - LoveGT40 Modelworks
website www.alsoldatino.com
my YT channel : https://www.youtube.com/channel/UCIp..._as=subscriber
FB: https://www.facebook.com/alsoldatino
The Following User Says Thank You to lovegt40 For This Useful Post:
Capri-Schorsch (02-14-2021)
  #233
Old 02-14-2021, 04:27 AM
Go on.
The Capri was primed so far and now also filled with nitro filler. There were very few holes in the body.
Now it's time to fine-sand and then prime with white.
Will definitely be the Würth version by Klaus Ludwig.
greetings Christian
Old 02-20-2021, 02:47 AM
Update:
The Capri has now been primed in white, the later base color.
Grind again and then comes the next layer which can hopefully remain the last.
Besides that, I started this vehicle.
First of all, the rough unevenness was removed with a 2k spatula and then spray spatula was applied.
Much remains to be done here.
greetings Christian
Old 02-23-2021, 01:49 PM
Thanks AJ!
Update Capri:
I painted the front spoiler and the doors with the airbrush.
With the spoiler, the decals wouldn't have worked.
Let's see how it works with the black on the fender. Maybe I have to do some paint afterwards.
greetings Christian
Old 02-24-2021, 04:41 AM
Borjacho's Avatar
Borjacho Borjacho is offline
Amazing work. As your other works, it's really interesting to know and see how the kit is created from zero, with all the problems you have solved during the process, explaining also for what this is included and for what not. Thanks for sharing, and of course for create this rare kits.
The Following User Says Thank You to Borjacho For This Useful Post:
Capri-Schorsch (02-28-2021)
  #237
Old 02-25-2021, 08:38 AM
Midnight Creep's Avatar
Midnight Creep Midnight Creep is offline
Nice work CS.
I can see u put a lot of time to get to this result.
I made an open version of this insane car and what i'm missing on your model is an opening vent in the bottom of the rear windowframe, because there is an oil cooler underneath it in the booth, on the left side of the fuel tank.
Here's a picture of my model showing what i mean.
Keep up the good work
Thx for watching, Greetz Peter
Old 02-28-2021, 10:42 AM
Thanks for your comments.
I know there was some versions of the car with the airintake for the oilcooler.But there are also some versions who dont got that.
They changed the car from race to race.
So i deceieded to give up to create the 100% perfect copy of that car.Not enough good period pictures and too much of restored cars.
And at the end when the cars is finished and in the cabinet nobody sees what is missing or not.
Live is too short to get all details right.
Most of the decals have now been applied.
A few are still missing or need to be changed.
But come this week and then there will be clear varnish.
I still have to dab a little black by hand around the rear window and on the fenders. The decals were too small.
And if you look closely at the prototype photos, you will discover different stickers and designs on each vehicle. I have now decided on an original car from the Nürburgring race.
greetings Christian
Old 03-07-2021, 04:33 AM
Decals have now all been applied. Now touch up with the touch-up pen and then apply clear coats the next weekend.
First construction site completed.
regards Christian
Old 03-07-2021, 11:39 PM
michel1973's Avatar
michel1973 michel1973 is offline
looks stunning, what is the overall size of this model
my English is not perfect but hopefully be readable
The Following User Says Thank You to michel1973 For This Useful Post:
Capri-Schorsch (03-10-2021)
Ford Capri Zakspeed Turbo Gr 5 Iskandana Completed Projects / Gallery 8 07-14-2010 04:37 AM
1966 Honda S800 - Doyusha 1/12 edwing666 Completed Projects / Gallery 5 04-28-2010 09:35 AM
89-94 Mercury Capri Convertible Questions RedMetroJet General Discussion 0 12-06-2009 01:45 PM
1/12 Scratch Built LMP1 mike@af WIP - Motorsports 22 06-18-2007 05:21 AM
Finally my Tamiya Porsche 935 Turbo Martini 1/12 finished bart8016 WIP - Motorsports 7 12-28-2002 05:44 AM
