Old 04-25-2009, 11:17 PM
Street18 Street18 is offline
Re: How Many Miles on Your Lumina
Originally Posted by chebbyguyz71 View Post
I have a 96 lumina 3.1 I purchased a month ago from my work for 250 bucks. It has 320k miles on it and still goin strong! Original engine and tranny. No rebiulds just routine maint. and a intake gasket. Im lovin my old boat. I got it to drive back and fourth to work but I drive it all the time. My 04 z71 just sits in the driveway lol.
My '97 Lumina hit 320,909 miles yesterday, and its still strong, the only thing i had to replace was the head gasket once.
Old 04-29-2009, 10:27 PM
merit4242's Avatar
merit4242 merit4242 is offline
Send a message via AIM to merit4242
1998 lumina 173,816 with a full engine and transmission replacement
Old 04-30-2009, 03:18 AM
Bearwulf's Avatar
Bearwulf Bearwulf is offline
284K on original engine, just replaced eng.(spun a bearing) with used one has 70K, put in new timing set and rod & main bearings.
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
Old 07-01-2009, 12:20 PM
steelers4life75 steelers4life75 is offline
A little late to comment on this but........95 Lumina 3.1 with 204,000 on it today. The only things (other than the fluids, belts and tires) that have been replaced since owning it, is the water pump and passenger rear brake reservoir. It still has the original battery from 1995 but she is losing some paint.
Old 07-01-2009, 01:24 PM
biffbart biffbart is offline
96' 130,000..no major repairs..water pump, starter,
Old 07-06-2009, 06:55 PM
bigbadbronxy2k5 bigbadbronxy2k5 is offline
Wow. Guess I have baby mileage lol. 134,500 on the clock, original engine, tranny rebuilt by NYPD. All thats gonna change come August, gettin' a rebuild on the engine and starting to build my suspension.
Old 07-11-2009, 12:27 AM
lorenzcat lorenzcat is offline
'92, 3.1, 159,765 miles. bad struts and fuel pump replaced last year. ignition control module today and ball joint broke, too. however, all parts were original to the car, as are the spark plug wires and who knows what else. i am hard on cars, i don't watch out for potholes or slow down on railroad tracks, so, for a 17 year old car, that is pretty good. always starts right up, no matter what the weather and talk about get up and go! i love this car. i do have some rust around the lower body, but this is Michigan after all. i would recommend a Lumina to anyone considering buying used. the newer models, i don't know anything about.
Old 07-24-2009, 02:06 PM
rjstang's Avatar
rjstang rjstang is offline
My 96 3.1 has 176k on original motor running strong and smooth. Original owner told me he had replaced some of the upper engine components.
Old 08-01-2009, 12:55 AM
Bearwulf's Avatar
My mom just bought a '97 w/3.1, 76,000 mi. Am doing tune-up & LOF this weekend.
97-Lumina LS
Old 11-28-2009, 09:41 AM
goodol55's Avatar
goodol55 goodol55 is offline
Send a message via Yahoo to goodol55
Thumbs up Re: How Many Miles on Your Lumina
I have owned My 1990 2 Door Euro since 1991, and bought it with just 10,000 miles.
It now has 272,000 miles on it. Original Motor and transmission etc. Went thru a few ECUs, lots of rear brakes, a Headliner, a paint job, and it just keeps going. Although I have some idle issues where it hunts for idle when warm/closed loop, and I'll solve it pretty soon. But the best part, EVERYTHING WORKS! At 20 years old, that's just about as good as my '55 Chevy.
VIN 2G1WN14T0L9269737 in New Jersey
Old 11-28-2009, 11:40 AM
Blue Bowtie's Avatar
Registered Offender
I finally retired my daughter's Lumina after 178K and replaced it with a 2001 Impala. The newer car is still a W-body so it may have a chance. With all these examples of quarter-million mile Luminas represented here, tell me again WHY I'd bother looking at a Honda or Toyota. That Lumina was in two accidents and both were walk-aways. One was with a snow plow and required a hefty bit of repair (straightening the floor), but the body integrity spoke for itself. I'm very thankful she wasn't in a Civic in that episode, or I wouldn't be becoming a grandfather soon.
What really did the car in for me was the rust. Once the rockers and floor rails start going, it's time to recycle. I would have driven that car any distance without hesitation if it weren't for the salt-induced corrosion. Had GM done a better job with galvanizing the rockers and floor, everyone would be driving Luminas.
Old 11-28-2009, 07:03 PM
kevinb70 kevinb70 is offline
Send a message via AIM to kevinb70 Send a message via Yahoo to kevinb70
I have had my 98 lumina parked/garaged for about 2 years, needs the LIM. 2nd time, 1st replacement was plastic around 2002, before i knew about the pre-felpro improved gasket. torqued it perfectly and it still failed. Been cranking and driving around the parking lot, but worried about the tranny once i get it going again. going to backflush the coolant passages with water/air because of all the sludge from oil/coolant mixing pray the heater core doesnt eventually clog. using regular antifreeze this time
have the magnaflow direct fit cat in the garage - my cat is toast no doubt from the coolant, and going to go down and pull the heads, blast, paint, do some light machining on them. check cylinders and replace all gaskets, clean the heads, replace lifters maybe springs, the 100k mile overdue timing belt/chain
car's been in the family since new, bought it from my sister when it was 8 months old, her company car before she quit to raise a family.
..having more fun in the dodge ram forums now than lumina forums
Old 12-07-2009, 07:23 PM
svotta svotta is offline
I have a 1990 lumina that just turned 85,000. If i keep changing the oil every 2300 and keeping up on maintenance it should last at least another 100k
Old 01-02-2010, 12:11 PM
unboundtrucker unboundtrucker is offline
Send a message via Yahoo to unboundtrucker
Mine is a 2000, with a 3.1 And she has 254750 miles on her. Doesn't leak or burn a drop of oil. Has all the power she had when I got her with 32,376 no major repairs either. So take care of yours and you might just be able to will it to yer grand kids
Old 01-22-2010, 02:10 AM
jamesmetairie jamesmetairie is offline
1998 (base model) 3.1 litre .bought with about 45,000 miles and now has 120,000 miles . replaced intake manifold with a felpro. replaced alternator. replaced belts and water pump before they expired. several brake jobs performed and brakes still lousey as usual . coolant level sensor malfunctioned and i just disconnected it. car refuses to track well. all in all better than the average car on the road and i,ve owned about 40 used cars.
How many miles do you have on your TB ? Is your truck ticking ? gkelly455 TrailBlazer | Trailblazer EXT 5 05-26-2006 12:11 PM
How many miles did your Prelude go... NJMAXSELTD Prelude 5 01-01-2002 04:09 AM
How many miles does your G`s put on each year? Primera-TDLX General 13 09-14-2001 05:52 PM
