Old 07-23-2003, 07:10 PM
mech0t0's Avatar
mech0t0 mech0t0 is offline
Detail master! I like the cell phone!
Old 07-23-2003, 07:52 PM
freakray freakray is offline
AF Modelrater
Phil, the interior is stunning.
Have a hundred questions for you though
What did you use to make the tie-down for the spare tire?
All the fittings on the tunnel, which ones are actually kit and which ones are after market/ home made. For the after market ones, which manufacturer's items did you use?
Thanks.
Ray
AF User Guidelines
Old 07-23-2003, 09:42 PM
RallyRaider's Avatar
Zomby Woof
Thanks.
Ray
Thanks Ray.
All the stuff on the centre tunnel is kit parts with the exception of the mobile phone. Just added some wiring (elastic actually) with a bit of detail painting and drybrushing. I built up the join between connector and wire with glue and paint to represent the rubber sealing grommet.
The spare wheel straps are painted newspaper, I usually use Tamiya tape (as I did with the seat belts) but the strap had to double back on itself so needed to be painted on both sides. The centre ring is a PE part off the S27 Lancer set intended for the bonnet pins. The ratchet/tensioning/locking thingy-ma-jig (can't remember what it's called - it's on the tip of my tongue!) is pieced together out of leftover PE bits from an M&A Corolla and 2000 template set. Looks a big improvement over my previous attempts to model the tiedowns, if I do say so myself.
Still raining
Old 07-23-2003, 09:48 PM
crismag crismag is offline
very very nice
Old 07-24-2003, 12:09 AM
Zomby Woof
Back again, is good to be home from work modeling
Found a problem when I test fitted the body to the chassis. Namely very large gaps visible in the wheel wells. I’ve not seen a Tamiya kit as bad in this area before. Probably made worse by my raising of the suspension, at tarmac height it would be less noticeable. So I had to find a way of fill the gap in. I’ve seen may people do this on AF and elsewhere by making an insert for the wheel well, so decided to give it a try.
Made them up and test fitted them to a second Evo VII bodyshell I have. Here are the prototype inserts for the front…
…and rear
Here is the difference it makes. First the front, looking back without the mask…
…and with.
Next the rear without…
…and with.
If anybody building an Evo VII would like a copy of the templates for the wheel arch inserts let me know and I’ll scan them.
Old 07-24-2003, 12:29 AM
NME NVADR NME NVADR is offline
Wow, that's one nice evo. Could you give me a link for that yellow carbon fiber? I was thinking about doing a rally car, but then I looked at your's and now I'm going to do one for shure. I might do the lancer too but I am a suby freak so, I'm thinking of doing the subaru 01 wrc.
Current project: Nissan Skyline GT-R V-spec II
"Speed costs money, how fast do you want to go?"
Old 07-24-2003, 06:12 AM
Zomby Woof
The yellow is Kevlar. On this model I used Museum Collection Kevlar decal, available at places like HobbyLink Japan or Rainbow Ten.
You could also try Scale Motorsports Kevlar which has an even more detailed pattern.
Old 07-24-2003, 05:00 PM
Ghost_9418's Avatar
Ghost_9418 Ghost_9418 is offline
Thats is looking amazing. Its the best rally I have seen, period.
Ryan
If your new to the AF modeling forum please read this : AF modeling FAQ
Current Project:
Tamiya Porsche Boxster Special Edition
Old 07-24-2003, 09:42 PM
Zomby Woof
Here is the scan of the wheel arch inserts.
They're probably not needed if the original ride height and tarmac wheel/tyres are stuck with. Make two mirrior images for left and right. Fit them after the chassis has been fitted into the bodyshell. Will need some CA glue or strong double sided tape to hold in place.
Mika's Lancer is now finished. Completed pictures here
The Evo VII, is it any good?? Chris Lancer 123 10-25-2003 04:14 PM
We might not get the Evo VII, people... VQuick Lancer 68 03-27-2002 01:52 PM
is the evo VII the same as the oz version? dnellienell Lancer 3 11-08-2001 02:55 PM
So is it for sure that the EVO VII is coming 2002 Deepcover6 Lancer 5 11-07-2001 05:19 PM
Do any of you know if the EVO VII will be an RS2 or the GSR when it comes to the US Deepcover6 Lancer 7 11-03-2001 11:53 AM
