Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-07-2006, 05:57 PM
96transamguy88's Avatar
96transamguy88 96transamguy88 is offline
bump stops????
i need knew bump stops, if thats what they are even called. im not sure. but i need the 2 rubber pieces that are in the rear end for the suspension. where can i get these? my car details are in my sig
1996 Trans am-
lt1 6spd
pacesetter lt's
ory-pipe
160* thermostat
slp fan control switch
4:10grs
cobra wheels
slp intake
hurst short throw
magnaflow catback
Daily Driver-86 4wd danger ranger
Old 11-07-2006, 06:17 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: bump stops????
i know what you mean. My brothers z28 used to scrape the tires in the wheel wells becuse some dumb ass cut them out, any ways i think i saw either jegs or summit had them. They had 3 diffrent sizes also. i will try to find them for you.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 11-07-2006, 06:21 PM
97cavalier's Avatar
Re: bump stops????
here you go, http://store.summitracing.com/egnsea...4294925130+115
Old 11-07-2006, 06:23 PM
Re: bump stops????
thanks man, ya my tires are so wide they hit the inside fender edge.... thanks for the help
1996 Trans am-
lt1 6spd
pacesetter lt's
ory-pipe
160* thermostat
4:10grs
cobra wheels
slp intake
hurst short throw
magnaflow catback
Old 11-07-2006, 07:34 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: bump stops????
How do those help keep the rear from grinding? Mines got the same problem. Got some 18's with 275's on em and every time I turn a corner all you hear is a screech. I'm guessing mine doesnt have them either, because I've never seen anything like those on that website on the rear of my car. I have seen a place that looks to be where they would go. But theres just 2 holes and nothing else.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 11-08-2006, 09:03 AM
Re: bump stops????
ya man i have 17's with 275's on them to..... but ya there is supposed to be 1 one each side.... i can post pics of mine when i get new ones if that would help... kyle
1996 Trans am-
lt1 6spd
pacesetter lt's
ory-pipe
160* thermostat
4:10grs
cobra wheels
slp intake
hurst short throw
magnaflow catback
Old 11-08-2006, 09:16 AM
gmack221's Avatar
gmack221 gmack221 is offline
Re: bump stops????
They keep the rear axle from hitting the frame in a full jounce condition (called a jounce bumper) (when you land your car and all the weight of the car + momentum push down on the body). does anyone know if they are even necessary on this car? Summit doesn't show them for my year ... doesn't mean they don't have it though.
The turning issue you have is front tire hitting the inside wheel well or power steering pump whine, or bad rack & pinion, check out the inside of your front tire, sounds like it will show wear, if there is nothing there then check your power steering fluid, look at the rack & pinion (what turns the front wheels) for leakage (mines about shot too).
Old 11-08-2006, 09:31 AM
Re: bump stops????
ya mine are gone in the rear... when i changed my fuel pump my dad ripped the left one off because it was so bad......i cant narrow the ones for my car down on summit either.
1996 Trans am-
lt1 6spd
pacesetter lt's
ory-pipe
160* thermostat
4:10grs
cobra wheels
slp intake
hurst short throw
magnaflow catback
Old 11-08-2006, 10:11 AM
gmack221's Avatar
Re: bump stops????
call the dealer, they can't be more the $15 each ... hopefully
or call summit or jegs ... on the phone they are pretty helpful!
Old 11-08-2006, 12:01 PM
Re: bump stops????
ya thats what i was going to do... hopefully the dealer isnt high in price.. if so im callin summit.. thanks guys for all the help.
kyle
1996 Trans am-
lt1 6spd
pacesetter lt's
ory-pipe
160* thermostat
4:10grs
cobra wheels
slp intake
hurst short throw
magnaflow catback
Old 11-08-2006, 04:00 PM
blindeyed's Avatar
eBay aDdict™
Re: bump stops????
Yeah man, if you could post some pics that would be great.
No, the front tires turn just fine. The grinding sound I get only happens when my car starts to lean while in a turn which is then causing the rear tires rub on the wheel well. I already tried grinding down some of the wheel well, and that helped a little bit, but it still does it. So are the bump stops supposed to help keep the car from leaning or something? Would they even help in my situation?
- Jason
Old 11-08-2006, 05:14 PM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
Re: bump stops????
Poly rear bushings can help keep the axle from moving back and fourth as bad when you hit a hard corner.
If its rubbing only on one side the rear end may be a little off-centered. A adjustable panhard rod can fix it if its only rubbing on one side.
Air shocks can help keep the tires from rubbing too. I havent seen air shocks listed for fourth gens, but third gen shocks will fit. The only problem is, the back will sit up higher once they are pumped up.
Old 11-08-2006, 10:39 PM
97cavalier's Avatar
Re: bump stops????
my brothers z28 did the same, every little bump we hit it scraped SO bad, you could smell the rubber. He had Torque Thrust 2's 17's with 275's in back. He never was able to get the bump stops because the car craped out.
