Old 07-06-2003, 03:10 AM
iawix iawix is offline
Send a message via AIM to iawix Send a message via Yahoo to iawix
4-2-1 or 4-1?
Hi all, this is my first post. I'm looking into headers for my 99 Civic LX.
I'm looking into getting some DC Sports Headers. I have heard that 4-1 headers increase torque from 4000+ RPM range and up.
But I have heard elsewhere that 4-2-1 headers help with low-end torque? Is this true.
Ultimately I plan on buying headers, then a high-flow cat and I picked up a glasspack this weekend. I am going to get some brackets and do me some welding to make everything bolt-on and then have an exhaust shop run pipe from the muffler back. Hopefully I'll be able to spin the tires after all this, and run better than the 18.3 I did at the track recently!
While I'm on the subject, I am planning on removing the stock resonator, as I'm under the impression that's what a glasspack does!
Thanks for any replies!
Old 07-06-2003, 04:42 PM
mastarolla mastarolla is offline
Send a message via AIM to mastarolla
4-1
4-1 is good if you want pure raw top end from the header, 4-2-1 sacrifices a little bit of that top end and puts it down lower in the powerband.
If i were you i would run the 4-1, Im happy with mine.
Old 07-06-2003, 04:50 PM
Options Options is offline
Send a message via AIM to Options
Personally i would go with the 4-1 headers.
Its not how fast you go it how fast you finish.
Second place is the first looser
Skunk2 Coil-overs
Aem 2 piece intake
Tanabe Exausht
Throttle Body coolant bypass
Apexi SAFC 2.
Skunk 2 cam gear.
ZEX dry nitrous system: currently 55 shot.
Best 1/4 Time:
16.402 @ 82 M.P.H w/ 2.290 60ft w/o spray 14.8@94 MPH w/ spray
Old 07-06-2003, 06:03 PM
moleodonuts's Avatar
moleodonuts moleodonuts is offline
Send a message via AIM to moleodonuts
yeah, you got your facts strait; I saw go 4-1 also. I'm a big fan of workin that high end. Then you let that person you're racing kinda get a lead before your 4-1 header kicks in and your turbo lag drops out and ka-boom you're ahead
95 Civic Si - Thunder Grey Exterior
-Performance: B16A, JR supercharger @ 9 psi, JR FPR, Tokico 5-wy Adjustable Shocks, Eibach springs, F/R strut and swap bars
-Audio: Alpine 9815, 3-way component Pheonix Gold speakers
Old 07-06-2003, 06:53 PM
umm
whoever said using a 4-1 header and the turbo lag drops when the motor hits the powerband....how are you running a turbo on a dc header? Just curious man... someone needs to get their facts straight.
4-1 is good for honda... especially since we have heads that are party harty for revving high. If it revs high you might as well make some available power up there or else its useless.
Old 07-06-2003, 07:07 PM
I just started listing off things that I could think of that add to high-end power but not low-end... I have jack done to my car so its certainly not me
Old 07-06-2003, 10:09 PM
Well bud, you won't see headers and a turbocharger on the same car! Just so you know, turbocharged cars use a turbo exhaust manifold, whereas a car that is N/A (no boost) will use a regular manifold (stock) or headers. Headers are basically a manifold optimized for more flow
I drive a 1999 Honda Civic LX 1.6L SOHC
Old 07-07-2003, 12:45 PM
<stands corrected>
prolly could have figured that out pretty easily if I thought about it... but hey, I have 0 experience with turbo so I didn't
Old 07-07-2003, 01:00 PM
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
Honda = HEADER (one)
Old 07-07-2003, 01:27 PM
Muscle cars = headers (two) ... what's your point?
2.4 blowing black smoke cr_rider Mighty Max 5 12-31-2010 03:56 PM
97 F150 4.2 Roaring PLEASE HELP stanley24538 F Series 7 10-25-2010 08:46 PM
2006 4.2L Manual Trans. redka88 F Series 2 01-04-2010 09:51 PM
Nissan Quest V6 to 2.4 ltr 4 cylinder swap Scraped Knuckles Quest | Presage | Serena 4 02-20-2009 09:59 AM
2.2 Vs. 2.4 Vs. 3.4 99DenaliMan Alero 1 09-20-2007 03:15 PM
