ML 320 ' 98 model - code P1570
Hi! I am retreiving code P1570 from the scan, Fault in DAS to engine control module. Vehicle is cranking over, then cuts off. All the remote keys are working. I have also cleared the trouble code and synchronized the key, but yet no result. Does the DAS module require replacement. Any further tests are required? Kindly post any info, would highly appreciate!! Thanks so much....Manoj
Re: ML 320 ' 98 model - code P1570
Hello
I have a problem similar at yours. did you solved ? can you share the answer ??? thanks MAuricio |
Hi! Yes this problem was solved. Firstly code P1570 states a failure in communication between DAS and engine control module.
Firstly make sure you synchronize the keys (this procedure is in the owner's manual), and all of them are operational. After this, confirm that DAS has authorized start on the key you are using. Follow this procedure: Between the foglight and low range switches there is a small LED. I think it blinks on and off when the truck is locked. If you unlock the truck and get in and just turn the key to "on" (just before "crank" position, you should see a very short blink of that LED, that means DAS is authorized is start. You can check your valet key, and remote keys this way. If you do not see the short blink, it's most likely a key problem. At the same time it's not likely that all your keys will be bad at the same time, but check them all. If the above checks out and your engine still does not crank, and run, or runs, and dies, then it's time to check for fuel pressure. Keep in mind that if you have a bad crankshaft sensor, you will not have any fuel pressure. Check fuel pressure, and then if you have none while cranking, jump the fuel pump relay. If you have pressure then, you have a bad crank sensor. If no pressure, a bad pump. In my case I had no fuel pressure, ended up being a bad crankshaft sensor. Replaced it, and the truck fired right up, and ran smooth. Hope this helps. Regards Manoj |
thanks for your help.
I gonna check all the procedure and let you know. thanks again Mauricio |
Hello
I made some tests, it seems that is a key problem, want to be sure do you have the instructions how to syncronize my key ? thanks MAuricio |
Hello
I checked the fuel pump presure 25 psi. but the immo LED IS NOT BLINKING it is completely dead !! is DAS module damaged ????? please any tips to look for the fault source thanks MAuricio |
#7 | |
hello
thank you very much for your techinical information. i have a cleint with the same problem.i checked the led is not blinking and the remote is not working,but he tell that this happened after changing the battery. what could the problem? thanks. |
