Go Back   Automotive Forums .com Car Chat > Pontiac > Grand Prix
Old 04-15-2011, 04:17 PM   #1
JonJon68
Send a message via AIM to JonJon68 Send a message via MSN to JonJon68 Send a message via Yahoo to JonJon68
1997 2nd design 4T60E Trans Bolts
Hi everyone. I'm looking for a part number for my 10MM bolt Transmission pan gasket. Only part #'s online that I can find are 24204624 Automatic transmission pan gasket used with 8mm pan bolts.
OR
24206182 Automatic transmission pan gasket used with 6mm pan bolts. are for the 6MM or 8MM
My bolts are the 10 MM. My 97 GPGT non-super charged is the second design for 1997. So is there a part number for the 10MM gasket that I need?
1997 GPGT 3.8 Dark Teal Metallic. 222000
4 door sedan
No Mods
JonJon68 is offline   Reply With Quote
Old 04-16-2011, 10:28 AM   #2
BNaylor
BNaylor's Avatar
Re: 1997 2nd design 4T60E Trans Bolts
Paul, the 4T65E uses M6X1.0X17 pan bolts total of 20 so you need the one for a 4T60E, GM RPO code M13. Double check the SPID label on the back of the trunk lid and make sure you see a code of M13.
The part number I have is 24204624. The part number 24206182 is for the 4T65E M15, MN7 or MN3 only.
Best thing to do is Send a PM to Rich (richtazz) to be sure.
Timeslip 08/12/06
AF Community Guidelines
BNaylor is offline   Reply With Quote
Old 04-16-2011, 10:54 AM   #3
JonJon68
Thanks Bob, I do have the GM RPO code M13, will double check with Rich..
4 door sedan
No Mods
Old 04-16-2011, 01:11 PM   #4
BNaylor
BNaylor's Avatar
Paul, also keep in mind the bolt size between the transaxles is based on the threaded part size not the head where you put the wrench. For example although the bolts are metric M6 on a 4T65E transaxle the bolt head size is 10mm. In other words you use a 10mm socket on them. Best thing to do is when you get the pan gasket (OE GM metal and preformed preferable) see if the bolt will fit properly through the holes in the gasket.
Timeslip 08/12/06
Old 04-21-2011, 01:50 PM   #5
JonJon68
Update: I called the dealership last Monday the 18th and I do have the 6MM, part number 24206182..Out of curiosity, I asked what their cost is...$49.00 and some change...Mmmm, no thanks....lol. I can purchase the exact same part for $20.00 less online..Thanks again for your guidance Bob..
4 door sedan
No Mods
4T60E Trans Trouble chevycountry88 Lumina 6 01-06-2011 12:08 AM
4T60E trans Redhead 27 Grand Prix 0 11-12-2004 11:40 AM
4T60E trans markcoc Eighty Eight 2 11-06-2004 02:36 PM
4t60e Trans...... cdurost Lumina 1 11-05-2004 10:48 PM
