Old 04-23-2009, 11:28 PM
kans0002's Avatar
kans0002 kans0002 is offline
The Best Interior Tan Color
Hey Guys,
What color tan do you all use for an interior color? I like Tamiya acrylics but will use anything.
Thanks in advance,
Stuart
Old 04-23-2009, 11:48 PM
taliesen's Avatar
taliesen taliesen is offline
Re: The Best Interior Tan Color
I'm far from an expert, but I think you almost have to mix a custom color for this. I like to take brown or tan and mix in some red and/or orange, and possibly some white or black to darken/lighten it up a bit as needed. Just make sure when you mix it up, you paint some on the same base color and let it dry, then see if you like the results.
Jonathan
Current projects:
1/12 Testors Lamborghini - http://www.automotiveforums.com/vbul...d.php?t=930745
Completed projects:
1/12 Porsche 934 Turbo RSR - http://www.automotiveforums.com/vbul...d.php?t=933988
No trees were harmed in the sending of this message; however, millions of electrons were terribly inconvenienced.
Old 04-24-2009, 12:19 AM
73superduty's Avatar
73superduty 73superduty is offline
Lost in plastic
I'm pretty happy with Tamiya Light Sand (TS-46). Then a coat of clear flat over it.
If you are trying to match a specific interior color, then mixing is the way to go. At the same time though, think outside the box. You'd be surprised at what colors are available at a craft store. You could almost match some interiors with acrylic craft paints.
Chris
Old 04-24-2009, 09:09 AM
kans0002's Avatar
thanks guys.
Old 04-24-2009, 01:08 PM
Didymus Didymus is offline
73Superduty suggested a good spray-can color, but there is no single color that's "best."
Interiors come in all shades of brown and tan. If you're trying to replicate a real car, it depends on the color of the original interior. Some Ferraris are upholstered with leather that verges on orange or yellow. I've seen a lot of Jag sedans with an eggshell color that's nearly off-white. The interiors of older cars were often medium brown. There are many exceptions, but American convertibles often had matching tops and interiors.
Otherwise, it depends on the color of the exterior and the shade of tan you like best.
If you have an airbrush, I suggest getting some flat-finish acrylics (Polly Scale or Tamiya) and mixing a color that works for you. If you don't like a completely flat finish, you can apply wax to the finished interior.
Ddms
Old 04-24-2009, 01:19 PM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
Best leather-like tan color I found is a Vallejo Air Sand, it's matt (TBH satin) and will be easily polished on much used spots, to me superb stuff.
On the other hand is water based, so not so easy to digest (or better to be cleaned) for our airbrushes, anyway some alcohol help.
gio
Old 04-24-2009, 01:50 PM
kans0002's Avatar
thanks again guys. it looks like i am going to be mixing up some custom tan!
Old 04-24-2009, 05:00 PM
rallymaster's Avatar
I use Citadel colors from "Games Workshop" and can find anything I want from tan to brown, at worst by mixing them.
Phil
Old 04-24-2009, 05:08 PM
Some_Kid's Avatar
Some_Kid Some_Kid is offline
I like testors random tan. Both Enamel and Acrylic are good. I recommend enamel though.
