Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 08-31-2009, 08:58 PM   #1
larrys 97
96 neon tranny problem
i have a 96 neon and after i drive it a while it wont down shift
larrys 97 is offline   Reply With Quote
Old 09-01-2009, 08:08 AM   #2
das2123
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: 96 neon tranny problem
I am assuming this is an automatic?
2003 Dodge SRT-4
das2123 is offline   Reply With Quote
Old 09-01-2009, 03:03 PM   #3
larrys 97
yes
Old 09-01-2009, 03:29 PM   #4
das2123
Could be time for a fluid and filter change and adjusting the bands.
2003 Dodge SRT-4
Old 09-01-2009, 08:07 PM   #5
thisnametooktolong
so I take it that it is stuck in high gear all the time? or do you mean that it does not Kick down? I take it that if you start out after starting it it shifts fine until you try to slow down the first time? If the darn thing goes one, two three. Then shut it off to get it in first... fluid and filter aint guna help
what do you mean?
thisnametooktolong is offline   Reply With Quote
Old 09-01-2009, 10:52 PM   #6
larrys 97
what do you mean?
it wont down shift
Old 09-02-2009, 06:25 AM   #7
thisnametooktolong
Adjust the throttle pressure control cable.
It is the same idea as a TV cable for GM, or fords old kick down linkage.
Pull the pressure lock tab slide the cable all the way toward the engine. Turn the kick down lever clockwise, until it hits the internal stop. Replace the locking tab, and let go of the lever. It should be adjusted. Take the car for a test drive it should be OK unless some thing is broken or worn out
Old 09-02-2009, 08:32 PM   #8
larrys 97
its down shifting ok now after i messed with it now it wont kick down into passing gear
