Old 02-08-2003, 01:12 PM
devonic devonic is offline
Knock Sensor
Hello,
I have a 97 civic dx(d16y7) and i swapped a 98 ex(d16y8) onto it. The guy sent me the y8's wire harness so i used that instead of using my y7's and then running wires to the ECU for it. Then put in my 98 EX ecu.Well went to go start it up and it wouldn't crank over. Put on the DX Ecu i had and it started up. I'm trying to figure out if it could be the knock sensor preventing it from starting with the EX ecu on it. I read somewhere that it retards the timing. Can anyone enlighten me on the knock sensor and what it does and if this could be the problem?
Any info i can supply, just didn't know what was needed.
Also i have 2 other questions
On the passenger side of the car, there is a wire coming off the harness by the battery that i didn't have a connection for. Its a blue plug with 2 inserts for prongs to go into
And on the drivers side right by the firewall theres a white plug coming out that i couldn't find a connection for.
Old 02-10-2003, 11:24 AM
Redline_civic91 Redline_civic91 is offline
Send a message via Yahoo to Redline_civic91
i think the nock sensor is the problem. it just tells your ecu if it senses knocks in the engine. i was without an knock sensor for about a month. it started fine, it does retard your timing with the engine code, but it should still start and run.
91 civic b20/vtec=sold
95 acura integra=sold
02 chevy silverado=totalled
95 honda accord=please i hope nothing happens to this!
Old 02-10-2003, 11:45 AM
yea i can get it to start, even took it for a spin yesterday. found a guy selling one so i bought it, found out the other plug on the drivers side is for the cruise control(which i dont got)
soon as i get it and the stock exhaust manifold hopefully my CEL light will finally shut off
Replacing Evap. canister Control Valve, Boost Sensor, and Knock Sensor? raja Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 16 06-04-2007 04:25 AM
Crazy knock in 3rd, o2 sensor or knock sensor bad? nates6969 Eclipse Problem Diagnosis 16 06-23-2006 10:11 AM
Knock Sensor and ECT Sensor snizzugglesmaxima Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 10-05-2004 07:53 PM
2000 Yukon How to Replace Fuel Sensor & Knock Sensor mrchiqui Yukon 0 06-24-2004 06:55 PM
Knock sensor and O2 sensor jmmax Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 02-24-2004 12:51 PM
