Old 10-02-2002, 02:21 PM   #1
amy@af
Traffic Directing Admin
amy@af's Avatar
Send a message via Skype™ to amy@af
error code need LX/DX/STD owners help!
hoopty whoop is having troubles. it is an 89 LX with my old d16a6 (from 89 Si). it doesn't have the MPFI conversion and it's stock ecu. the car think's it's still a LX (or DX/STD engine wise).
here's the deal...the last couple of nights it has gotten really cold. yesterday and this morning i have started the car and get a code 10 (intake air temperature). the car will start but drop idle rapidly until it dies unless you sit there with your foot on the gas.
could the problem be it doesn't like the custom intake in the cold? i took the air restriction plate out. could it just be sucking in too much cold air...would replacing the plate help? is a sensor freaking out on me somewhere? the problem didn't start until it got cold. anyone else ever have this problem?
after like an hr, pulled the hazard fuse and reset the ecu yesterday and it started. going to go utside and try it again in a few. it seems to work but i can't be doing this everyday i want to drive the car :toothless
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
amy@af is offline   Reply With Quote
Old 10-02-2002, 02:36 PM   #2
Melt
Melt's Avatar
Send a message via AIM to Melt
Sounds like you need to put that air restriction plate back in.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Melt is offline   Reply With Quote
Old 10-02-2002, 02:38 PM   #3
GTA
Whee..
GTA's Avatar
Hasn't happened to me, but it dont get that cold down here either Don't knwo why it would, try the resrictor plate first i'd say.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
GTA is offline   Reply With Quote
Old 10-02-2002, 03:54 PM   #4
mightytexn
mightytexn's Avatar
Send a message via AIM to mightytexn
to me it sounds like the engine is just too cold to run at idle, so i guess replacing the restrictor plate or the stock intake would fix it.
I'm Jordan
My car is the ugliest one on this board
mightytexn is offline   Reply With Quote
Old 10-03-2002, 11:56 AM   #5
kaytec4door
hey ur problem sounds like my friends crx when i did his first b16a swap. sometimes there is a cold engine sensor. well its not really a sensor but it is more of a diafram. when the engine is cold it holds the throttle plate a little open for extra air and as the engine warms it closes. it is located right by where the throttle cabel connects to the throttle body. the intake shouldnt matter though. but i would check it out on you engine. good luck though
let me know if you get it fixed
kaytec4door is offline   Reply With Quote
Old 10-03-2002, 02:02 PM   #6
JoshDM
hoopty whoop needs an Si computer or to perform the pgmi conversion and that should fix your problem:bonghitte
SiKiller
JoshDM is offline   Reply With Quote
Old 10-03-2002, 03:43 PM   #7
turbcivic
turbcivic's Avatar
Try switching to a colder spark plug range.
turbcivic is offline   Reply With Quote
Old 10-03-2002, 04:12 PM   #8
amy@af
amy@af's Avatar
it's not the pgmi. i didn't do the MPFI conversion. i've been rolling the car around town a couple of months. this didn't start until the weather temp. dropped dramatically.
it's not the restrictor plate. that was the easiest to rule out...so i stuck it back in this morning before i started the car. same thing happened. so i shutoff the car and reset the ecu. i expected the car to start right and and all is good as it had done the past 3 days. nope. threw a code 10 again. so the problem is getting worse. i was gonna check the plugs but it started raining. so the mystery will continue.
hopefully it won't rain tomorrow
01 Town & Country error code explanation jehanny Caravan | Voyager 3 10-14-2009 01:34 AM
92 PA Error Codes, need help agamino Park Avenue 7 04-03-2005 01:20 AM
99 GC heater error codes.. Need Help wranglers5 Grand Cherokee | Grand Cherokee SRT8 1 03-19-2005 03:41 PM
b16a Error Codes, Need help desperately K_millar Let's get Technical! 4 01-23-2004 02:12 PM
