Old 01-17-2007, 04:53 PM
831 Team Advantage 831 Team Advantage is offline
Re: clutch noise
Well i have a problem with my acura integra. The problem is that my car won't go int to first when i turn it on. But when i turn off my car the gear goes in with no problem. It makes a sound like coming from the head. I think is my clutch or something but i don't wanna guess. Any one has an idea what it can be. Thanks.
Old 01-17-2007, 07:46 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: clutch noise
Sounds like maybe your clutch master or slave cylinder is leaking past the seals. It lets the clutch creep toward engaging even though your foot is to the floor.
Describe a lot more for us... the head has nothing to do with the clutch, so a more detailed description is required.
Dragging people kicking and screaming into the enlightenment.
Old 01-18-2007, 03:57 AM
Re: clutch noise
Ok it sounded like the piping was hitting or something. So I thought there was something going out so i dicided to take it out for a spin. So when i was driving my car . In a red light. I put it in neutral and then I tried to put it into first but the car wouldn't go to i turned off the car. And the gear would go in. So i put it in first gear and the car run but it run like shit no power at all. When i pulled to this place my car wouldn't go in first no more. But i turned off the car and all the gear would go in, but the engine wasn't running. So when i turn the car back on the gears wouldn't engage at all. But a wierd noise was coming from the transmission. Like a dry noise. But it does have oil. I check it already. Maybe i hear the noise weird cause the motor it not running propely. Its hard to discribe it. Thanks
