Go Back   Automotive Forums .com Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 08-16-2002, 04:53 PM   #1
big ed
Oil level
I want to know how much oil everybody puts in there p10 . I have been putting three qts in and its a good level. The book says to put more than three. Is the dipstick off a little or what?
Pioneer Deck
Orion 4x6 in front
Phoenix Gold 6 1/2 in back
12 inch subs for the thump
big ed is offline   Reply With Quote
Old 08-16-2002, 09:16 PM   #2
urasula
I use 3qrts also. It'll be in the middle of high and low; u can add more if u want, but u'll end up with an extra bottle half full.
urasula is offline   Reply With Quote
Old 08-16-2002, 10:47 PM   #3
NismoPC
NismoPC's Avatar
Recommended oil capacity is 3 5/8 qts of oil with a new filter. That is almost a full 4 qts. If you are replacing your filter every oil change then you are practically running a high reving 4 cylinder almost an entire qt low at all times. That is not very good on the internals.
If you are not replacing the filter every change, then you only need to put 3 3/8 qts in. But I always put a fresh oil filter on every change.
Brandon
'96 G20 - modified
NismoPC is offline   Reply With Quote
Old 10-02-2002, 09:23 AM   #4
G-ealousy
G-ealousy's Avatar
Nismo PC was right on with that answer. when you put that new filter on, it's not holding any oil, so, when you put the 3 1/2 qts in it, it seems high, but, after it runs for 10 minutes, it goes down. You should definately be running more then 3 though. And you should change the filter every time... If you do 3 1/2, then that half comes in handy on your next change, cause you only have to buy 3 qts, not that big of a deal..
26,122 miles as of March 3, 2004
My real name is Kaizer Soze, but my friends call me Nick...
G-ealousy is offline   Reply With Quote
95 Lumina oil level sensor saxonmor Lumina 4 01-25-2011 12:27 PM
PRND321 Lights, Oil Level Light, Temp Gauge ktmccrary Grand Prix 46 12-18-2010 11:59 AM
Does the oil warning light have an oil level switch? dieter Caravan | Voyager 5 08-29-2009 04:36 PM
Oil level and oil pressure... zephram22 Aurora 7 10-31-2005 08:56 PM
Check Oil Level and Change Oil Now tbizzle Aurora 2 04-25-2005 04:25 PM
