Old 08-31-2002, 05:12 PM
wagsaccordsir's Avatar
wagsaccordsir wagsaccordsir is offline
Got a problem with my H22
Got a problem... I just had an OBD1 JDM H22 swapped into my 97 Accord. I'm experiencing some problems.. I have fuel in my oil, what would cause that? And does that have anything to do with smoke coming out of my exhaust? My car is running RICH.. How do I cure that, and are these problems related? Any help or advice would be greatly appreciated..
Old 08-31-2002, 06:55 PM
b16a3sol b16a3sol is offline
sounds like a head gasket problem to me. if its not that then my other guess would be blow-by. this means your piston rings are failing. run a compression test on each the cylinders to try and isolate the problem. both would account for the smoking exhaust, but i dont understand the gas in the oil thing. i dont think those two ever come into contact with each other enough to have a noticeable amount of gas in your oil.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Anyone got problems with front tires wearing off early? tydog8 Vitara 6 05-01-2009 07:54 PM
got problems with it running!!! plz help!!!!!! midnight_neon Probe 2 10-23-2004 02:28 PM
Got problems with a loose front end, think you need shocks, etc.. powering Jimmy 0 10-18-2004 08:02 AM
93 accord cruise control problem with H22 swap mast0075 Engineering/ Technical 0 12-15-2003 12:02 AM
Got problem with radiator fan integra 1988 alvin Engineering/ Technical 0 08-18-2003 09:21 PM
