Go Back   Automotive Forums .com Car Chat > Honda > Civic | CRX > '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV
Old 07-30-2002, 01:37 PM   #1
NuEra
Banned
NuEra's Avatar
rpm activated switch
OK, this is like the 5th thread I made on this. I cant seem to get the information I need, I have a rpm activated switch which Im hooking to a LED light to use as a shift light.
The rpm activated switch has;
-white wire = going to tach wire by distributer
-black wire = going to ground
-red wire going to 12 v source ( I wired to the back of the accesory socket to the yellow wire )
-yellow wire to LED bulb. ( the other side of the bulb is the problem)
The LED bulb has two prongs, the one is hooked to the rpm switch and the other side requires a +12 wire. I hooked it to the same wire as I did for the red wire, the accesory wire, right beside it. Is this hook up correct, because it didnt work, if not, which +12v wire should I hook it to?
NuEra is offline   Reply With Quote
Old 07-30-2002, 05:32 PM   #2
luti
Send a message via AIM to luti
Are you sure the yellow wire isn't sending 12v when its activated? If so then the other end of the LED should be going to ground. There is one other possibility, you have the LED wired backwards. Unlike light bulbs LED's are directional. You can only run power in one side and ground out the other, if you reverse it nothing will happen. Try swapping the connections around.
T3/T04E turbocharged ricer.
luti is offline   Reply With Quote
Old 07-30-2002, 08:12 PM   #3
NuEra
Banned
NuEra's Avatar
Good info! Do you know how the LED lets you know, because they come with one side longer than the other. Ill try swapping anyway. I know there is current because I used a test light. The other thing is, do you think splicing into the same wire twice is ok??, because thats what I'm doing(one spice to the rpm switch and the other to a side of the LED). thanks
Old 07-30-2002, 09:48 PM   #4
luti
Usually the long side of the LED gets the 12v. I think. But, if the wire from the switch to the LED has 12v then the other end of the LED must just be connected to any ground. Splicing into a wire twice is fine, its even easier if you just use one splice and put all the connections at that point.
Old 07-30-2002, 11:01 PM   #5
94hatchsi
where did you find the rpm activated switch and if you got it from a website would you mind posting a link or something
thanks
94hatchsi is offline   Reply With Quote
Old 07-30-2002, 11:06 PM   #6
NuEra
Banned
NuEra's Avatar
sure,I got it from racer parts wholesale , it doesnt look like like much, but it should work.
Old 07-31-2002, 01:48 PM   #7
NuEra
Banned
NuEra's Avatar
Finally, it works!
Old 07-31-2002, 09:19 PM   #8
luti
Ok, I've been thinking about doing this same mod myself for quite some time. Which wires did you connect to where? How much was the switch? Where did you put the LED?
Old 07-31-2002, 11:20 PM   #9
NuEra
Banned
NuEra's Avatar
OK, I know I did a good thing now that I made the guide on how to do it. Luti, go to the interior forum to find the how to I made on this. The RPM switch is like $50 and an LED from radio shack cant be more than $2. So what you get is a shift light for $52. I put the LED on the bezzle around the gauge cluster, where there was nothing behind it. Just cut a hole and they make LEDs that snap right in, it looks great, and low profile.(I.E. sleeper and is original rather than the big junker lights on the market) Ill get a pic as soon as possible but for now check out that guide. Write if you have any questions.
Old 07-31-2002, 11:27 PM   #10
NuEra
Banned
NuEra's Avatar
Heres my LEDs, Vtec and shift light.
installed shift light with rpm activated switch now no tach reading help!!! B16Civic93 Let's get Technical! 0 06-27-2004 12:23 AM
WOT+activation switch teg2nd Forced Induction 1 10-16-2002 10:10 AM
MSD RPM activated switch & VTEC 91civicDXdude '88 - '91 Civic | CRX | Wagon | Shuttlee 13 09-21-2002 03:31 AM
RPM activated switch NuEra '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 07-25-2002 04:40 PM
RPM Activator Question 90CRXZCSi '71-'87 Civic | CRX 10 03-23-2002 01:31 AM
