Go Back   Automotive Forums .com Car Chat > Ford > Windstar
Old 01-08-2012, 05:06 PM   #1
Black_Blade
How to locate a short in electrical system?
My 02 has been sidelined for last week because something is killing the battery. Put my meter across the battery cables and sure enough, there is a direct short somewhere, now the big question of where to even begin trying to find out where this short is occurring! There must be a thousand miles of wire in it!
Also, a weird thing happened when I put my battery charger onto the battery to get it started a few days ago, before I had checked for the short, for I thought in the cold weather the battery just died on me. When I plugged the battery charger into the outlet to start the charging, one headlight flickers on, I never seen anything like that before, light switch was off keys not even in ignition...thats what made me think that there was something funky going on with the wiring, but several hours later the battery was charged enough to start the van. (the one headlight was no longer flickering, so at some point in the charging process it stopped doing that)
Black_Blade is offline   Reply With Quote
Old 01-08-2012, 05:10 PM   #2
aleekat
Re: How to locate a short in electrical system?
Hook your meter back up and start pulling fuses. Once it drops, you have narrowed it down to a circuit that runs off that fuse.
aleekat is offline   Reply With Quote
Old 01-08-2012, 05:30 PM   #3
12Ounce
.... also pull relays, that's what they are for ... sectionalizing the electrics
12Ounce is offline   Reply With Quote
Old 01-08-2012, 07:52 PM   #4
Black_Blade
Thanks guys, will start with that and see how it goes...just what you wanna be doing in the middle of January...lol.
Old 01-14-2012, 02:23 PM   #5
Black_Blade
Well, as a follow up on my problem, I went through fuses and checking with ohmmeter. Finally got to the 25A (rear wiper motor, rear washer pump, rear wiper relay) in the box beside the battery to locate the one that had the issue.
I removed the fuse and put the battery back in, fired her up and let it run for a good spell to warm it all up. All seemed fine after a bit, so took daughter to work and then grabbed some take out to bring back home. The van had been running for a good 3/4 of an hour by now with no sign of trouble, so I turned it off to get the take-out food. Came back out and it barely turned over, but then caught and ran.
Now though, it was so low on power that all the lights in the cluster were flickering and fading out, it got worse if I accelerated. Limped it back home and checked the voltage across the battery with it running.
With all accesories off: 13.3 volts
lights and heater fan going: 11.5 volts (I did notice at stop lights before that the fan speed would reduce and then increase once stepped on gas when light went green)
I just replaced the alternator 2 yrs ago, but sure looks like its pooched again I guess and prolly ruined the battery as well for its been undercharging for quite some time now that I think about it. The fluctuation in heater fan speed has been going on since cold season started. Couldn't afford to fix alternator at the time...
Old 02-04-2012, 11:23 AM   #6
Black_Blade
I have installed new alternator and battery. Also replaced a battery post clamp (neg), will be keeping an eye on it for corrosion build up. With engine running have 14.3 volts across the battery.
The resistance across battery cables, disconnected from battery is 5K, would anyone be able to verify if this is OK, or should there be even higher resistance?
Old 02-04-2012, 12:45 PM   #7
12Ounce
That alternator voltage is much better ... that's for sure! Not sure about the open circuit resistance ... would think that is a bit low. Does your model have the special cabin fuse (#17 IIRC) that is pulled for long-term parking?
Old 02-04-2012, 12:52 PM   #8
aleekat
Because battery cables are a low resistance circuit, checking for ohms is not reliable. You need to do a voltage drop test. Here's two links that may help:
http://www.aa1car.com/library/voltage_drop_testing.htm
http://info.rockauto.com/CarCareforC...Ch6SmplPgs.pdf
Old 02-06-2012, 07:18 PM   #9
Black_Blade
Will look into doing this, having some trouble locating a 1ohm 10 W resistor though. The Source has next to nothing anymore in the way of hobby electronics parts etc, don't know why they bother with the few pieces they still have...
Old 02-06-2012, 09:52 PM   #10
wiswind
Very roughly......that 5K ohms on the 12V battery would be a draw of 2.4mA......or 0.0024 amps
Not a big draw.
Not something that I see killing a battery overnight.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
wiswind is offline   Reply With Quote
Turn signal shorts entire electrical system! dahirolla T100 2 09-13-2009 10:21 PM
Electrical System Shorted trickett123 Metro 1 02-08-2006 08:39 PM
Short circuiting electrical system overtheradar Engineering/Technical 0 09-12-2004 01:41 AM
Short circuiting electrical system - '79 323 overtheradar General Discussion 0 09-12-2004 01:38 AM
electrical system shorting out sriddle Continental 1 08-10-2004 10:14 AM
