Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 07-27-2005, 03:57 PM   #1
4800Esox
Unhappy 02 Leaking Differential Fluid
I think I noticed the leak before any damage occured. I was wondering if anyone else had a similiar problem with thier S10 at 80K miles. To me it just seems to early for the seals to be failing
4800Esox is offline   Reply With Quote
Old 07-27-2005, 10:54 PM   #2
OverBoardProject
Banned
Re: 02 Leaking Differential Fluid
When I changed the fluids on mine it had no leaks, and possibly as much as 200,000 miles
It appeared to be the first time that this job was ever done.
OverBoardProject is offline   Reply With Quote
Old 07-27-2005, 11:30 PM   #3
bigd7315
Send a message via Yahoo to bigd7315
i had had several and no leaks and most have had many miles on them where is yours leaking from
bigd7315 is offline   Reply With Quote
Old 07-27-2005, 11:47 PM   #4
bigd7315
Old 07-28-2005, 08:37 AM   #5
4800Esox
Re: Re: 02 Leaking Differential Fluid
I dont know the exact name for the part but its where the shaft enters the differential. The underside of the truck is covered in oil from it spraying around.
I am a little disappointed with the truck. so far I have fixed the starter, electronic fuel assembly, gas gauge, drivers side window motor. All the repairs were easy to fix but it all happened after the warranty was up. I drive my cars into the ground so I plan on having this truck for many many more years. After all a fixng a truck is so much chaeper than car payments.
Old 07-28-2005, 07:39 PM   #6
rlith
rlith's Avatar
Send a message via AIM to rlith Send a message via MSN to rlith
My front diff was leaking at the seal for the longest time...(would loose about 2 pints between oil changes) Finally just dropped the bloody thing and put in a new gasket, no probs since.
95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal
rlith is offline   Reply With Quote
