Go Back   Automotive Forums Car Chat > Engineering/ Technical > Kit Cars
Kit Cars Replicas, rebodies, customs or engineering. Talk about it all here.
Old 04-28-2005, 05:28 PM
KrazyNeon KrazyNeon is offline
Send a message via AIM to KrazyNeon
what is this?
I'm working on a special project and saw pictures of what would be the perfect transmission, however i have no idea what transmission it is. Can anybody identify it??
Any info is greatly appreciated, thanks.....
Old 04-29-2005, 11:58 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: what is this?
It looks like an automatic transaxle from a C5 vette. That's the only longitudinal transaxle GM car I can think of.
Dragging people kicking and screaming into the enlightenment.
Old 05-03-2005, 01:36 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: what is this?
i beleave you're right curtis
i just entered the part number on http://www.trademotion.com/partlocat...eid=715&val2=2
it comes up as Rear suspension - Axle and differential - Carrier assy - Auto trans
3.15 ratio 1997 - 2004 - list price $1544.23
Old 05-05-2005, 04:46 PM
Re: Re: what is this?
yea, that's for the rear 3.15 differential.... what is the transmission part of it?
Old 05-08-2005, 03:33 AM
curtis73's Avatar
Re: what is this?
The transmission is a re-hash of the 4L60E that they call the 4L65E. Ratios are:
1st = 3.06
2nd = 1.63
3rd = 1.00
OD = 0.70
Its a wide ratio tranny best suited to either flat torque curves or extremely light bodies.
C5 and C6 vettes use a non-traditional driveline. The LS1 engine is up front, but the transmission is in the rear attached to the final drive differential. Typically the layout goes, engine-tranny-driveshaft-differential. With C5 and C6s, the layout goes, engine-driveshaft-tranny-differential. The driveshaft becomes an extension of the crankshaft and the tranny is in the tail.
Old 05-10-2005, 10:48 PM
YES!!! thank you so much! With the info u gave me, i found even more.... but.... i can't seem to find HOW the crankshaft is connected to the driveshaft
I know the engine has a funny looking bellhousing with a small bolt pattern connecting to the torque tube, but what I'm interested in is the connection between the crankshaft and driveshaft. Does the driveshaft go right into the crankshaft itself? Or is there a piece that connects the two?
