Old 03-15-2005, 04:14 PM
clozepin clozepin is offline
Need to replace a cigarette lighter
I've never replaced a cigarette lighter before, and any help would be appreciated.
My lighter no longer works, and as I use it to plug various devices in, this is a bit of a pain. How do I go about removing and replacing a lighter? I can get the panel off, but the lighter doesn't just pop out like I had hoped. I can't really see what's going on behind the panel, and I know that if I just keep pulling, I'm gonna break something.
Thanks.
I have a Saturn SL1, 1995.
Old 03-15-2005, 10:18 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: Need to replace a cigarette lighter
Chances are the lighter itself isn't bad. They are simply a metal tube with a contact in the middle. There is really nothing to fail about them. It would be like if your cell phone died and you replaced the battery contacts. Chances are they aren't to blame.
Use a test light or multimeter to test the lighter socket itself. If you're not getting juice, test the wire at the back. If you're getting juice to the wire but not the socket (which would be rare) then you need to replace the socket.
Chances are its a loose wire or a blown fuse.
Accessing those panels is usually a pretty straightforward thing. They do their best to hide bolts and stuff. Look clear at the bottom of the panel you wish to remove and you'll probably find several screws. Then, most times the panel is held on by little push-on studs or tabs. Try gently pulling and see where its hanging up.
Dragging people kicking and screaming into the enlightenment.
