Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 03-25-2002, 02:39 AM
sama sama is offline
95 g20 5spd idle problem
Hi Guys,
I have a 95 g20 5spd. I turn on the car and if the clutch is out and in neutral, it sometimes seems to go from 1k rpm to 100-200 and almost turns off then goes back up to 1k. Its weird, sometimes while normally driving, it seems to not transition the gears slowly. There are 2 possible problems that I can come up with, either the O2 sensor or the clutch is slipping. The car still has the original clutch as far as I know (100k miles) and driven very smoothly and never raced. Anyone else encountered this same problem?
Thanks guys.
Old 03-25-2002, 09:53 AM
NismoPC's Avatar
NismoPC NismoPC is offline
If the car is in neutral with clutch fully disengaged, you should not be experiencing the idle drops. It is not the clutch. So.....
-Check to see if your throttle body is clean
-Check the MAF ground wire
-Make sure your plugs, wires, cap and rotor are in good shape
-Check the EGR and make sure it's not clogged
-Check your base idle and
-Check your timing
That should cover all the bases. Most of the procedures can be found on www.se-r.net or you could search the forum and see if they are posted.
Hope this helps!
Brandon
'96 G20 - modified
88 chev. g20 van idle problem ghfreebird Express | G Van 9 02-01-2011 05:30 PM
Clio 1.2 16v 2002 Expression idle problem!! stuuuu Clio/Clio II/Clio III 1 05-03-2010 03:59 PM
1995 SL Idle Problem peliknhed LS/LW 1 07-07-2009 08:30 PM
2001 Dodge Grand Caravan ES idle problem Rookie Tech Caravan | Voyager 3 07-03-2009 12:27 PM
00 Focus ZX3 5spd Idle Problem devin123 Focus | C Max 1 10-09-2006 01:00 AM
