Old 02-17-2005, 10:17 PM
dirtracer25 dirtracer25 is offline
Question Oil filter question?
guys,
I have been having trouble with my race car blowing oil seals on my oil filter in cold weather. I have always been a fram fan!. recently i was told about a aluminum oil filter that can be taken apart and is good for life? any thoughts or comments, good or bad?
i found the filter at www.trufilter.com
thanks
DR25
Old 02-17-2005, 11:51 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Here are some articles I think you should check out. Fram is actually one of the worst filters you can buy. The first is a study of a lot of popular oil filters. The second is an e-mail from an Allied Signal production engineer that works with Fram filters. The third is an overview page about the different oil filters covered in the study.
http://minimopar.knizefamily.net/oilfilterstudy.html
http://minimopar.knizefamily.net/oilfilter-fram1.txt
http://minimopar.knizefamily.net/oilfilters.html
Also, this is more an engineering/technical question. There is a better forum for this. I'll move it there.
Old 02-18-2005, 12:07 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: Oil filter question?
I used Fram filters for years without problems, but after seeing one cut open, I've never used one again. Bypass valves made out of cardboard, holes in the paper filter that you could see through... Not pretty.
Dirtracer: The gasket isn't one of Fram's problems, so something else is wrong. Using a different filter won't be the proper fix for the problem. The problem sounds like a sticking oil pump pressure regulator spring. The cold oil develops much more pressure than hot oil and it blows the gasket out.
Dragging people kicking and screaming into the enlightenment.
