Old 02-27-2004, 11:20 PM
jeffseby's Avatar
jeffseby jeffseby is offline
Send a message via AIM to jeffseby
Question Easy Question about cooling fan? How does the Radiator Cooling fan know when to Come
How does the Radiator Cooling fan know when to Come On? It may be from the Coolant Temp Sensor, but I thought that wire only goes to the Gauge....?
Ya, It's Turboed.
Old 02-29-2004, 01:25 AM
rubix777's Avatar
rubix777 rubix777 is offline
Send a message via AIM to rubix777
doesn't the thermostat trigger the fan?
Old 02-29-2004, 10:15 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
its the thermostat activates it.
Stable Of Cars I have Owned:
1991 Honda CRX
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: Easy Question about cooling fan? How does the Radiator Cooling fan know when to Come
Fanswitch.
Old 02-29-2004, 07:14 PM
jeffseby's Avatar
I concure, the thermostat is a just little spring thing that opens at 180 Degrees, it just lets the coolant flow, it has no electrical connections at all.
Maybe the ECU just activates it every five minutes or so??? but I don't know.
Ya, It's Turboed.
Old 03-01-2004, 01:46 AM
rubix777's Avatar
then why is the thermostat the first thing someone changes, when their fans do not automatically turn on?
Old 03-01-2004, 11:08 AM
I don't know who that someone is, but if my fan doesn't come on, I change the fanswitch.
Old 03-04-2004, 08:10 PM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
There are two sensors/resistors for the ECT. One I think runs on 12V which goes to the gauge on your cluster, the other runs on a 5V reference voltage for the ECU.
The ECU sends a 5V out to the sensor/resistor and reads the voltage after it goes through the sensor to determine the temperture, if necessary, the ECU will send a signal to the fan relay/switch to active the fan.
It's not necessary the fan relay or switch that cause the fan not working, you will have to run a test to check what componet is the cause.
Now for those who read this post and gain some knowledge please send a "civic build up fund" to my paypal account ([email protected]) if you can.
Thank you.
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
Old 08-07-2004, 03:05 PM
bryan.az bryan.az is offline
i got a 96 integra that the fans dont switch on at all does anytone got any clues, the relays and fuses are fine but still no power to either fan???
Old 08-07-2004, 04:35 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
how do you know hte relay is fine ?
Team Lonely Drivers
Old 08-08-2004, 01:57 AM
GWInquisitor14's Avatar
GWInquisitor14 GWInquisitor14 is offline
Send a message via AIM to GWInquisitor14
Tofuboy hit the nail right on the head. When the CTS sends back a certain voltage, it changes that into a temperature and when it gets so hot, it turns the fan on. All the thermostat does is open up to let coolant into the engine. If it didn't, the fan wouldnt turn on because the air rushing past the radiator would always be cooling the coolant and there would be no hot energy from the engine to transfer into it thus no need to turn on the fan.
If the car really knew about all this trickery, hed be pretty mad.
FOR SALE
2 10" Alpine 1041 Type R
JBL BP 1200.1 1200 watt RMS amp
Message me if you are interested, make me an offer
Old 08-11-2004, 12:19 PM
almxdupintegra almxdupintegra is offline
It should turn on as soon as you turn on the AC, at least in my car thats how it goes on
FRIENDS DON'T LET FRIENDS DRIVE STOCK
Old 08-12-2004, 07:08 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
theres a 2 pin connecter on the thermostat housing, thats the sensor that turns on the cooling fan... if you want to test that sensor cuz your fans dont run, try using a jumper wire between those 2 wires on the connecter, that should make them run... if the fan works the sensor is bad
gunnmen01
My other ride..... is YOUR MOM !!!!!!
what side does the larger cooling fan mount on a 1997 dodge neon? thecrow1986 Neon | Plymouth Neon 1 07-05-2007 06:53 PM
How to Replace Radiator Cooling Fan tabbie07 Cavalier Problem Diagnosis 10 08-14-2006 08:34 PM
How does the horm ring come off? murocflyer Charger R/T | Charger SRT8 1 01-04-2004 06:18 PM
