Old 12-15-2004, 03:13 PM
solaris=amazing's Avatar
solaris=amazing solaris=amazing is offline
Question How Much Juice is in My Batt.?
How can i tell if my battery is charged up to a good point..? Without using battery testers or any other similair device..
If i put my cars ignition in the ON position (to make the accesorys work/but not start the engine) my volts gauges has the needle right after 8 (the volt gauge says (8 volts 18) and the needle is on the v of volts.
Also, i have a very good battery charger (which don't display how much juice the battery has) but jumped several cars in the past, except mine. How would i use this to fully charge my battery-can i leave the battery connected in the engine bay, or should i dismount the entire battery, then connect my charger?
Old 12-15-2004, 03:15 PM
Re: How Much Juice is in My Batt.?
BTW, when the car is running, the needle on the volt gauges is on the T of volts..
Old 12-15-2004, 04:41 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
its generally a good idea to disconnect the battery terminals from your car when using a battery charger
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 12-15-2004, 06:13 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Depending on your charger, it should tell you. Most of the old style chargers have a gauge on the front that says how many amps its taking. The more amps its drawing the more charge it needs. I usually disconnect it when its below 2 amps since that is pretty well charged. Newer chargers turn off automatically.
The car's voltage gauge is a good representation, but it usually just tells you relative things like if its overcharging, undercharging, or somewhere acceptable in between. The numbers are usually just there for decoration
If it runs well and keeps the battery charged then it should be fine forever. Just keep that "T" reference in your head. If the gauge starts averaging out at the "V" instead, you know you've lost some voltage and its time to check other stuff.
Dragging people kicking and screaming into the enlightenment.
Old 12-17-2004, 02:20 PM
sracing's Avatar
sracing sracing is offline
You can't without a tester or good digital volt-meter.
The dash gauge is very inaccurate and only good for relative rough readings IE. It should read higher when the car is running than stopped. This at least tells you that the charging ciruit is working.
If you trickle charge it below a 20 amp rate you can leave it connected. If you charge it at a rate higher than 25 or so, I would disconnect it, just to protect your ECM, radios, etc.
If you charge it at a 5 to 10 amp rate you can leave it on for many hours with no risk. I would simply check it periodically to make sure it stays below 10Amps.
If you charge it at a rate below 5 amps or so you can leave it on indefinately.
Jim
SR Racing
Old 12-17-2004, 09:01 PM
LudeLuxury LudeLuxury is offline
take it to Canadian Tire, they'll test it for free :P
(that is if you live in Canada)
