Go Back   Automotive Forums .com Car Chat > Mitsubishi > Eclipse 2000+
Old 12-31-2003, 06:13 PM   #1
tfling
Din cable in a Infinity system
Does anyone know where I can get a extra din cable for my infinity system?
Thanks
Tony
tfling is offline   Reply With Quote
Old 12-31-2003, 06:46 PM   #2
johnnyBgood
Send a message via AIM to johnnyBgood
Re: Din cable in a Infinity system
Mitsu dealer.
johnnyBgood is offline   Reply With Quote
Old 01-27-2004, 08:15 AM   #3
bluehose1989
Did the dealer have what you needed? I recently bought an Infinity stereo with a 10 disc changer that does not have the din cable. The unit came out of a mitsubishi. I am planning on installing the unit in my boat but have not been able to purchase the cable at any car audio retailers. Any info would be appreciated.
bluehose1989 is offline   Reply With Quote
Old 01-28-2004, 07:09 AM   #4
tfling
The Cable was $150.00 at the Mitsu. dealer
Old 01-28-2004, 12:57 PM   #5
eclipseGTO
eclipseGTO's Avatar
OUCH. You didn't buy it did you? Go to a website selling cables and see if they have a cable like that. If not they could probably make one for you. Shouldn't cost more then $50.
eclipseGTO is offline   Reply With Quote
Old 01-28-2004, 05:24 PM   #6
tfling
no I didnt buy one. I am going to build my own, but I need a wiring diagram so I get the pins right.
Old 01-28-2004, 07:31 PM   #7
eclipseGTO
eclipseGTO's Avatar
Are you using the factory amp as well? or are you using your own amp?
WHere are you going to get the din connectors to build the cable?
If you are not using the factory amp then something like that would work.
ANyway, correct me if i'm wrong but the Infinity uses a 5 pin din cable.
You can buy one for about $4.
GO HERE to check out the cables.
Old 01-28-2004, 07:39 PM   #8
tfling
thanks man
Old 07-15-2004, 01:31 PM   #9
galaxie500
and the amp??
i have a 1991 mitsubishi montero, and just purchased a 4 disc in-dash stereo from a 2001 eclipse to replace the monty's failed old cassette system. i have no cabling -- but i do have a stock infinity amp. being an audio tech loser, i have no idea what to get to make the system work. i have the factory harness adapter to properly fit the new stereo to my 91 montero, and i have an accompanying infinity amp from a 2000 eclipse. what powers the amp? i don't know what hooks to what, blah blah. can anyone help an idiot??
galaxie500 is offline   Reply With Quote
Old 07-16-2004, 07:23 PM   #10
tfling
Cables
well the amp needs the black din cable that comes from the Headunit. If u dont have one then I would try looking for it on the forums. It cost alot to get it from mitsu.
Old 07-16-2004, 10:24 PM   #11
galaxie500
is the din cable the only cable that connects to the amp, or does it need anything else?
Old 07-16-2004, 11:06 PM   #12
tfling
There should be another white rectangular connector that connects ur amp to the speakers, this maybe difficult to get if ur vehicle didnt have the infinity system originally.
Aftermarket audio system in a '96 Jeep GC ltd. w/ infiniti system. BadAceGolfr21 Grand Cherokee | Grand Cherokee SRT8 15 11-21-2007 04:33 PM
Finally a factory CD radio for 1 DIN non-Premium system kru General Discussion 0 09-08-2006 01:39 AM
Aftermarket Amp Install on Chrysler Infinity System 01 LXi Coupe Car Audio 5 03-23-2004 11:47 AM
Stock amp in the infinity system? druid_goldeyes Golf 0 01-08-2004 07:46 PM
Infinity System ? 03stratrt Car Audio 5 09-15-2003 08:20 AM
