Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Talk
Old 05-28-2004, 11:00 AM
flashstang04's Avatar
flashstang04 flashstang04 is offline
(another) gear question
Old 05-28-2004, 12:07 PM
Re: (another) gear question
Old 05-28-2004, 01:08 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Originally Posted by flashstang04
I have decided to go with 4.10's on the advisement of all of the fine stangers on the site.
one more question: Except for the speedo, do I need to change the chip for anything.....I think someone had told me that here.
What vehicle? If its newer you program the calibration in correct. On older models you need a new speedo gear to calibrate for the gears.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 05-28-2004, 01:21 PM
Re: Re: (another) gear question
sorry... it's an 04 Gt
Old 05-28-2004, 02:51 PM
brentmcq brentmcq is offline
Seems like the going rate. I have shopped prices at 4 shops in Phoenix for 410's and they are in the 600-700 range full install including bearings and seals. If it's just the gears that's too much.
Old 05-28-2004, 04:38 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Gears+ install average is $500 so use that as your ballpark.
on an 04 GT your speedo needs to be fixed electronically not with a speedo gear.
If your getting a chip you can correct the speedo through the chip and don't need the speedcal.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
