Go Back   Automotive Forums .com Car Chat > Dodge > Caravan | Voyager
Old 03-14-2005, 08:31 PM   #1
mdhbhouse
heater/AC fan not working
I have an old 91 Plymouth Voyager and starting today the heater stopped working. I mean you try to turn it on and nothing, no blowing of anykind (hot or cold). The rear heater still works and I can control it from the front as always.
Is this a fuse problem or more of an electrical problem. Everything else seems to still work. I've visually checked the fuses but I don't actually see anything labeled as heater or fan.
I'll double check fuses for something blown but wanted to start with a post.
I've seen a number of posts about no heat (thermostat related etc.) but this is not my problem. Just doesn't trun on!
TIA, Mark
mdhbhouse is offline   Reply With Quote
Old 03-14-2005, 09:32 PM   #2
mdhbhouse
Re: heater/AC fan not working
Update:
Checked and replaced 30A fuse in slot 26 label'd A/C-HTR fan.
No change
TIA, Mark
Old 03-14-2005, 11:03 PM   #3
yogi_123rd
Another possibility to check: It could be a blown relay that supplies the power.
yogi_123rd is offline   Reply With Quote
Old 03-15-2005, 05:01 PM   #4
mdhbhouse
Re: Re: heater/AC fan not working
Strangely enough it is working again today after being parked in the garage overnight? Last night I started surfing around and found some hints on heater blower replacements and a blower motor resistor failures
Let's say is was a relay. Those are under the hood in a line with other realys's right (never claimed to be a mechanic )?
Right now I guess I'm in a wait and see situation although I plan on investigating how I would find the heater motor resistor and how you'd test a heater blower motor.
