Go Back   Automotive Forums Car Chat > Car Audio
Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music.
Old 04-18-2004, 03:31 PM
makaveli3004 makaveli3004 is offline
Capacitor??
hi i just recently purchased a system for my 97 camryi got a 200 wat deck 1000 watt amp and 2 12" subs. i noticed that at night when the bass hits the lights dim. someone told me over time this will kill the alternator and that i need a Capacitor to fix this. i was wondering what Capacitor would be good enough to get cause i see ones with different Farad ratings
Old 04-18-2004, 03:36 PM
bmwm3guy's Avatar
bmwm3guy bmwm3guy is offline
Banned
Send a message via MSN to bmwm3guy
Re: Capacitor??
i think a 1 farad capacitor shoudl suffice in your setup.
Old 04-18-2004, 03:49 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Capacitor??
what specific amp do you have?
Since you said your headunit is "200 watt", I'm assuming your "1000 watt" amp is closer to 300 watts. If that's the case then you don't need a capacitor at all, just upgrade the magic 3 and make sure you gain is set correctly. If you don't know what the magic 3 is then just run a search, it's been discussed a million times.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 04-19-2004, 10:53 PM
Re: Capacitor??
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3092690115 that is my amp
Old 04-19-2004, 10:54 PM
Re: Capacitor??
sorry i meant thi link please delete last one http://www.bestbuy.com/site/olspage....oryId=cat03087
sr20de4evr's Avatar
Re: Capacitor??
Well assuming you're running it at 2ohm, you're only getting 400 watts out of that amp. That's not near enough to overload your electrical system. Upgrade the magic 3 and you should be set.
'01 Black Sentra SE
'05 Silver WRX STi
Old 04-19-2004, 10:58 PM
Re: Capacitor??
i searched for the magic 3 i could not find it where should i search for it. also if its only runniogn at 400 watts how do u use the other 600 watts
Old 04-19-2004, 11:22 PM
sr20de4evr's Avatar
Re: Capacitor??
http://www.automotiveforums.com/vbul...d.php?t=215435
And there are no other 600 watts, you have a 400 watt amp that's labelled as a 1000 watt amp. Welcome to the wonderful world of peak power ratings that mean nothing. It's technically not false advertising, since they can simply say the 1000 watts is the peak power, even though it really doesn't make 1000 watts even if struck by lightning. It's a screwed up world....all of the mainstream brands follow this rating system, you have to read the specs themselves to find out what power the amp really puts out.
'01 Black Sentra SE
'05 Silver WRX STi
Old 04-20-2004, 12:40 AM
burly burly is offline
Re: Capacitor??
Whenever shopping for an amp, look for RMS and per channel ratings, not peak values and overall amplifier power ratings. Unfortunately, most if not all companies in the market advertised on peak power, which is useless in practice.
As for your dimming, upgrade your grounding points, check the gain and as long as you don't have any other additional aftermarket high current draw products installed, then you should be ok with the stock alternator and without a capacitor. If you do have other high current draw devices, then thats a whole new ballgame.
Car: 2003 Malibu (Base)
Modifications: KC Fog lamps, autodimming rearview mirror w/ compass&temperature, window tinting, rear speakers, front speakers, sub, synthetic ATF & aux tranny cooler.
Future modications: Dynamat interior, alloy wheels & new tires, intake, exhaust & intake manifold???
