Go Back   Automotive Forums .com Car Chat > Pontiac > Grand Prix
Old 11-01-2002, 11:17 AM   #1
bigwilley
Angry Courtesy Lights Won't Shut Off
On a 1998 Grand Prix, the courtesy lights will not shut off unless I pull the fuse. What could be wrong? I've tried everything I could think of.
bigwilley is offline   Reply With Quote
Old 11-01-2002, 07:44 PM   #2
CopperHed210
Banned
Send a message via AIM to CopperHed210
Courtesy Lights,also know as Day Time Running Lights.They dont go of.They are made to stay on whenever the car is on.Whats the big deal with them being on anyway?
CopperHed210 is offline   Reply With Quote
Old 11-01-2002, 08:20 PM   #3
bigwilley
I actually meant what could also be known as the "dome lights", however, since it has a moonroof, it's not really a dome light, there's one light right in front of the moonroof, and two lights in the back on the sides.
Old 11-02-2002, 08:49 AM   #4
CopperHed210
Banned
O ok.They do go off after awhile.But if yours arent going off at all then theres probably a problem in the door(s).
Old 02-24-2004, 01:35 AM   #5
executive
Send a message via MSN to executive
Re: Courtesy Lights Won't Shut Off
I had this same problem. There are switches near the front door hinges which get pushed in when you close the doors that turn off cabin lights. I found out that the driver side switch wasn't getting pushed in far enough (you can test it with your finger) so i just glued a piece of cork to the edge of the door where it makes contact. Good luck.
executive is offline   Reply With Quote
Old 02-24-2004, 01:24 PM   #6
solideo7
solideo7's Avatar
Send a message via AIM to solideo7
I don't mean to undermine your intelligence (which I am not), but sometimes the simplest solution is overlooked. I do that all the time.
Did you check the dimmer switch? If it is clicked all the way to one end, the lights will stay on.
2000 Silvermist Grand Prix GT
Thrasher CAI, RT Cat w/3"downpipe, U-bend delete, ZZP Rockers, ZZP 180 T-stat, ZZP Stage I HVTB, ZZP HVIMI
solideo7 is offline   Reply With Quote
Old 02-25-2004, 10:36 PM   #7
osiris1910
Check to see if there is a relay in the headlight switch. I'm not familiar with that year, but the older GTP's(93) have a relay in that switch. Mine stuck on and the only thing I could do was pull the fuse until I replaced the switch assembly.
Hope this helps.........
osiris1910 is offline   Reply With Quote
Old 02-27-2004, 10:45 AM   #8
kilroypr
kilroypr's Avatar
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
I would go checking the door switches(The cork thing works). If that is not the problem, does your car has the delayed turn off feature? Because if the door switches are ok then the BCU could be the problem since it is the one that controls the delayed turn off feature.
kilroypr is offline   Reply With Quote
Old 02-28-2004, 12:54 AM   #9
osiris1910
Not sure about the "cork thing". The lights do work on a 30 second delay though. It is controlled by a timing relay in the headlight switch "pod". Like I said, I'm not sure about other years. Try the public library. That's where I got the schematics for my car (They have the GM tech manual). Hope this helps.
94 Lincoln Continental: Lights won't turn off TheWampusCat Continental 8 01-12-2014 11:56 AM
94 pontiac Grand AM- ABS light won't shut off and inside lights won't shut off ACWweasel Grand AM 4 02-26-2005 04:46 AM
Courtesy lights won't turn off umina Grand AM 7 11-04-2004 11:22 PM
Courtesy lights won't go off. jmelaragni Bonneville 7 09-08-2004 03:46 PM
Interior Lights won't shut off even though the switch is OFF and DOORS are fully shut Tough Blazie Blazer 5 03-02-2004 11:25 AM
