Go Back   Automotive Forums .com Car Chat > Honda > Integra
Old 02-03-2002, 03:14 PM   #1
Hybrid Boy
Banned
Hybrid Boy's Avatar
Send a message via AIM to Hybrid Boy
Skunk and Edelbrock intake manifold just a type r manifold?
Ok, I want to get an intake manfiold sooner or later.. But I was wondering... Are those aftermarket Skunk2 and the edelbrock intake for any bseries engine just a replica of the type r one? Thanks
Hybrid Boy is offline   Reply With Quote
Old 02-03-2002, 03:43 PM   #2
engsr
engsr's Avatar
they are not an exact replica. the Type-R manifold has a different bolt pattern than the dual-stage manifold. therefore, you would have to drill a different set of holes on the Type-R one. The Skunk2 and Edelbrock have a direct bolt pattern, therefore no modification is required - just slap that bitch on, and go. hope this helps.
Bryan.
Pure Honda member since August 2001
AF Nordic Crew #002
engsr is offline   Reply With Quote
Old 02-03-2002, 04:09 PM   #3
00GSR
Correct me if I am wrong, but I believe that the Skunk2 is basically the same as a port/polished Type-R manifold...So although it is a replica, it is not quite exact
00GSR is offline   Reply With Quote
Old 02-03-2002, 05:12 PM   #4
Hybrid Boy
Banned
Hybrid Boy's Avatar
ok, so here goes again... I have an LS engine.. I know people say b series are interchangeable.. So could I just slap on the skunk2 intake manifold(seeing as id have to buy a new intake, and throttle body) but could i? thanks
Old 02-04-2002, 12:57 AM   #5
00GSR
www.skunk2.com
Skunk2 Racing Intake Manifold
The most restrictive part of a factory induction system is the intake manifold, but an appropriate aftermarket replacement has never been available until Guide Group-A Autosports has successfully designed the Skunk2 Racing Intake Manifold. The Skunk2 Racing Intake Manifold has substantially improved flow characteristics over the factory unit. Dyno-testing has shown an 8 to 15 hp increase on naturally aspirated applications at the wheels. The Skunk2 Racing manifold is also perfect for forced induction applications. The Skunk2 Racing manifold is available for DOHC 1.6-1.8 VTEC and non-VTEC engines and is designed to utilize all factory sensors. Use of this manifold will not affect emissions.
Old 02-04-2002, 07:31 PM   #6
T.O.tegs
the ITR I/M and skunk2 I/M are pretty much the same...
edelbrock I/M has way shorter/fatter runners....in my opinion great for f/i but not for n/a
WUTS DAT
AF nordic #7 foo...you better recognize:finger:
T.O.tegs is offline   Reply With Quote
What Edelbrock Intake should i go with? inforcer958 General Discussion 4 02-14-2011 08:58 AM
Replace Intake Manifold Gasket Stammtra Cougar 4 07-20-2010 01:13 AM
2002 2.7L Intake manifolds ksparticuspa Intrepid 1 07-02-2010 03:25 AM
Looking for and edelbrock vortec intake & beehive valvesprings inglewatt102 Engineering/Technical 1 05-11-2009 01:51 PM
Edelbrock intake manifold ras_2680s Integra 0 02-12-2004 01:59 AM
