Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > C/K
Old 01-20-2004, 02:20 AM   #1
jsnowbordr47
Opinions on Suburban Sound Systems
I have a 95 Suburban LT with the Premium sound system option. I was thinking about putting better speakers like say 6.5 3 ways in all the doors, and 4X10 3 ways in the back. Then the guy at Best Buy told me that if I really wanted better sound, that I should consider ditching the Delco, and adding a 300 watt amp. I asked him if I could just keep the Delco, and add the amp, he said I couldn't. So I was just wondering what your opinions are about the Delco Stereo. Should I just buy the speakers only, or should I buy the speakers, and ditch the Delco.
And if so what should I go for? A Rockford Fosgate amp, and one of those in-dash video decks? I don't know much about stereos except that mine doesn't sound very good compared to my friends kenwood with 2 12 inch subs.
Thanks,
jeff
jsnowbordr47 is offline   Reply With Quote
Old 01-20-2004, 11:17 AM   #2
Dr. Eagle
Re: Opinions on Suburban Sound Systems
Thanks,
jeff
I had a 92 Suburban and I put in a Phoenix Gold 6 channel 600 watt amp, Pioneer stereo, single 12 sub and Phoenix Gold speakers all around. It was a kick ass stereo, in fact I pulled the amp, sub and swapped for a lower quality stereo when I sold it.
I think you are likely to find that the Delco speakers will either fry or you'll find out they are jacked up and you don't realize it when you put the extra power on them from an amp. You can do it incrementally, but if you want really good sound, do the whole system.
Just my .02
Dr. Eagle is offline   Reply With Quote
Old 01-22-2004, 01:10 AM   #3
blueburbboober
hows this,
i work at best buy, and i own a 95 burb. (crazy huh?) i just dropped a system in. ill give you some pointers. ditch everything stock!
that being said, the rest is up to your budget. the 4x10's in back will suck regardless, its a terrible speaker design. the pioneer ones will work ok as a replacement. the 6.5's can be replaced with whatever you can afford and think sounds nice. you dont need an amp. anyone that says you do is a moron. if you can crank a 50wattx4 system in a burb and tell me its not loud enough, you need hearing aides. if you want subs, then you will NEED an amp. again all this depends on your budget.
the most important thing you pick out is the head unit (cd player) pick out one that has mp3 support, and has preouts for subs with all the adjustments and crossovers built in. (the pioneer 7500 is a nice one) if you can affordin dash dvd, go for it!
lemme know what you decide.
-Rob
No more burb for me!!
2005 Jeep Wrangler. Blue, 4.0L
2004 Jeep Wrangler Unlimited. Bright green, 4.0L. No mods yet on either!
blueburbboober is offline   Reply With Quote
Old 01-26-2004, 11:18 AM   #4
rasta
Re: Re: Opinions on Suburban Sound Systems
I just bought a 93. I need to replace everything. When I replace the head unit, does the new one go right in where the old one was or over in the slot where the tape player is? What kind of adapter is needed and how expensive is it?
rasta is offline   Reply With Quote
Old 01-26-2004, 06:55 PM   #5
blueburbboober
on a 93 you need a spacer that will make the head unit stick out about 1.5 inches. it will go in where the tape deck is. you will also have to go to the dealer or the junkyard and get a "cubby hole" or filler plate to put where the radio controls are. my friend had it in his 88, and it doenst look too bad at all, just make sure the spacer is COLOR MATCHED to your interior. (in other words pay attention to color if you order the part online.)
-Rob
Old 01-27-2004, 10:16 PM   #6
XSNOIZ4LIFE
XSNOIZ4LIFE's Avatar
Send a message via AIM to XSNOIZ4LIFE
...go to your local dealership and get the cubby blueburbboober was talking about...or better yet use the stock housing for the lower cd player to be your mold; i made a bitchin' switchpanel. If i can find pics, i'll post 'em.
A word to the wise...DO NOT REPLACE THE REAR 4X10's with the same thing...instead get an adapter from sounddomain.com or something and put something decent there...4x10's only sound good if you're on a desert island alone with no other alternative...TRUST ME!
"...traveling on the highway to hearing loss at the speed of sound..."
~XS NOIZ CUSTOM AUDIO INSTALLS~
XSNOIZ4LIFE is offline   Reply With Quote
1996 Suburban air bag system ground 1993Suburban Suburban 1 07-05-2009 09:50 AM
Need opinions about my new sound system. Bridq Interior | Audio | Security 24 04-19-2005 02:38 AM
Opinions On New System Powerefx Car Audio 57 02-26-2005 09:23 PM
give me an opinion on this system immortalbb Car Audio 10 11-14-2003 12:25 PM
Opinions on my system..? RiceBurninVTEC Car Audio 14 04-21-2002 04:21 PM
