Old 11-03-2003, 09:51 PM   #1
willimo
Sweet, sweet tiny Hondas.
How to make an air intake.
It's been asked a lot, and so I've decided to post the way I do it. This isn't really the best one to show since I didn't really score the tube very well, nor did I taper it and the detail isn't that good, but it's good enough to show you how to do it.
1. You'll need a length of styrene rod, or tube. Mine is 3/16. You'll also need a saw with teeth that aren't too close together, but mine are a little too far apart for this. If your saw is like mine you can do it twice to get the right spacing between the folds of the filter, since that's what you're going to do with this. The mitre box is just to help me, it's not totally necessary.
2. Lay the rod in the mitre box and press the blade against the rod. Then drag the rod under the teeth, the direction the arrows are pointing. This will score parallel lines in the rod. It just occured to me that I could have put the saw in one of the 45 degree angle mitres and it would have made the scorings closer together... oh well. Anyway, do this several times to deepen the lines, and then several more times all the way around the tube until the entire thing has been scored to look like an airfilter.
3. Saw out a portion to use as the airfilter. I'm using the second peice I cut off, the first is too small for my taste.
4. Punch some holes in styrene card, but keep the holes. Glue these to either end of the filter, and sand them to close to the same diameter. I've found it's easier to make a round thing smaller and round than a square thing the same size and round. Just the way I do it.
Glue the filter to a bit of styrene rod (this was bent from sprue) for the piping; paint and detail as you see fit. The connector is made from tape, painted, with metal foil on it. And there's the finished project. Simple, no?
Old 11-03-2003, 10:07 PM   #2
specmodeler
specmodeler's Avatar
Thanks, thats very helpful
specmodeler is offline   Reply With Quote
Old 11-04-2003, 07:19 PM   #3
blueboost
blueboost's Avatar
Re: How to make an air intake.
thanks bud, thats a great tutorial. obviously should go into our tutorial bank!!
blueboost is offline   Reply With Quote
Old 11-04-2003, 07:40 PM   #4
008
008's Avatar
Excellent!
008 is offline   Reply With Quote
Old 11-04-2003, 07:58 PM   #5
slk320
AF Premium User
Send a message via AIM to slk320
Very good method, very very helpfull. Similar to mine, I use aluminum tubing to connect the cone filter to the intake.
Thanks for tips!
slk320 is offline   Reply With Quote
Old 11-04-2003, 09:32 PM   #6
Honoturtle
Very Creative! The funny thing is, I recently got a mitre box and saw! I'll definaltly use this one!
AF MODELING FAQ
"Oh what a feeling.- Toyota
Honoturtle is offline   Reply With Quote
Old 11-06-2003, 01:13 AM   #7
chaos
AF Premium User
chaos's Avatar
Very nice!
chaos is offline   Reply With Quote
Old 11-06-2003, 09:16 AM   #8
bigfrit
bigfrit's Avatar
Thanks for the great tutorial , it will be put to good useage in the near future.
Olivier
Old 11-13-2003, 08:29 PM   #9
86_SR5
86_SR5's Avatar
Nice, I'm working on one of these How To's for Cold air intake (cept I'm using a filter, not making one) mad props to ya.
RIP Indian Larry RIP
April 28th, 1949 - August 30th 2004
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
86_SR5 is offline   Reply With Quote
Old 11-14-2003, 11:36 AM   #10
Ferrari TR
Not A Hoarder!
Ferrari TR's Avatar
Cool!
I knew how to do that, but the illistrated step by step instructions make it crystal clear!
KUTGW!
SCCA 7, The lost Z
Ferrari TR is offline   Reply With Quote
Old 11-15-2003, 04:43 PM   #11
eviloution386
that will make the fillter a hellava lot easier to make!!!
eviloution386 is offline   Reply With Quote
240sx s14 CARB Legal Cold Air Intake? Dope Minded Technical 3 01-26-2011 04:48 PM
'00 cavalier, odd noise and oil in air intake/throttle body warik Cavalier Problem Diagnosis 4 04-23-2009 07:11 PM
backfirea and caught air filter on fire!!!! davidrobert2 LeSabre 8 03-27-2009 08:22 AM
Make your own Cold Air Intake kicker1_solo Engineering/Technical 16 04-08-2004 12:36 AM
