Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 08-19-2003, 08:01 PM
abby777_2000 abby777_2000 is offline
Question keyless remote w/ alarm
We just purchased a 99 deneli and could someone please tell us how to program our remote w/ alarm.
Thank you,
Old 08-20-2003, 07:35 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Their are 2 different methods to program remotes one is this one::
If they key is in the ON position during the programming procedure, the horn chirp will be disabled, if the key is in the OFF position, the horn chirp will be enabled. The horn will chirp when the lock button is pressed two times.
When reprogramming the remote control door lock reciever, All transmitters must be programmed at this time in order for the transmitters to operate the vehicle. Transmitters not programed at this time will not work and the procedure will have to be redone with all the transmitters.
Ground pin 4 to pin 8 of the data link connector (DLC). The receiver will respond by locking and unlocking the doors, and activating the liftgate window release (if equipped) within 2 seconds.
Press and hold the LOCK and UNLOCK buttons simultaneously on the first transmitter to be programmed until the locks cycle (approximately 10 seconds).
Repeat step 2 for up to four total transmitters to be programmed (if available). The receiver will respond by locking and unlocking the doors and activating the liftgate window release (if equipped) within 2 seconds.
Remove the ground applied to the DLC.
Lock and unlock the doors in order to verify the transmitter operation.
Activate the rear window release in order to verify the transmitter operation.
THE OTHER PROGRAM IS THIS ONE:
Have each of the transmitters that you intend to program ready. This vehicle will allow you to program a maximum of four transmitters programmed at one time.
Turn the ignition to the RUN position, then back to the OFF position. This will disarm the theft-deterrent system.
Remove the RADIO fuse (Fuse 17).
Turn the ignition from the OFF position to the RUN position three times quickly, within five seconds. The vehicle will respond by locking the doors, unlocking the driver's doors and releasing the tailgate or panel doors. The transmitter is now ready to match to the vehicle.
Press and hold the LOCK (1) and UNLOCK (2) buttons on the first transmitter for 15 seconds. The vehicle will respond as in step 3.
Repeat step 4 for the remaining transmitters.
Replace the RADIO fuse.
Check that all transmitters work by pressing their buttons.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Program 2007 camry keyless remote marty.graw Camry/Camry Hybrid/Vista 1 03-31-2010 09:13 AM
chime indicating keyless remote error - 2003 Pontiac Grand Am Jcolli06 Grand AM 1 02-18-2009 07:37 PM
Keyless remote alarm and door locks jcg4life Grand Cherokee | Grand Cherokee SRT8 10 05-03-2005 05:37 PM
95 jeep grand cherokee keyless remote alarm nazeerl Grand Cherokee | Grand Cherokee SRT8 0 02-17-2005 10:08 PM
ford keyless remote alarm programming wolf62669 Explorer | Explorer Sport Trac 1 07-27-2004 03:59 PM
