Old 08-22-2003, 12:07 PM
egon_dude egon_dude is offline
Send a message via MSN to egon_dude
Question How do you make heat reflecting foil?
Im doing the exhasts on my 911GT1 and the reference pics ive got show that theres a lot of that heat reflective foil around them where the exhasts go through the suspension wishbones. Ive tried making this with plain old tinfoil, but it doesnt look right. Would it be a good idea to glue it to something to make it thicker? Ideas would be much appreciated!
Only smarties have the answer . . . .
Old 08-22-2003, 12:13 PM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
I've used the foil from cigerette boxes and chewing gum wrappers.
There are various textures...
Lead foil from wine bottles may also work, just shine it up with a little steel wool.
SCCA 7, The lost Z
Old 08-22-2003, 12:49 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
On my NSX I put some adhesive metal foil (ie Bare Metal Foil) on a single ply of two-ply toilet paper. Then I put it on something soft, my mouse pad, and smooshed it with my fingers to give it the crinkly texture. Then I used white glue to attach it to the firewall. I don't know how well this would work on something as irregular suspension arms, but thats what and how I did mine.
Old 08-22-2003, 04:56 PM
Midnight Racer's Avatar
If your low on budget just use aluminum foil.
Old 08-22-2003, 08:29 PM
scaleracecars scaleracecars is offline
Place a small section of screen material matching the pattern you want on top of bare metal foil. (while still on the original backing paper)
Burnish the screen into the foil making the pattern. Then cut out and apply using a cotton bud. You will want to use a very small quantity of glue to help hold it in place. Looks much better than any other method I have tried.
David
Wishcar: If you have half a Million Dollars, how would you make your dream car? xianriddick Cars in General 16 01-02-2007 10:00 PM
how do you make t.v's for cars what kind of material do you use and making amps eddie29 Diecast Car Modeling 2 05-30-2004 10:51 AM
How can you make a Passat faster? Can you? jimbo69ny Passat 2 02-07-2004 02:11 AM
How do you make a direct pipe from your exhaust to your engine to make it louder? Lingerie_Ripper Prelude 14 02-03-2002 11:20 PM
