Go Back   Automotive Forums .com Car Chat > Buick > Tips and Maintenance Procedures
Tips and Maintenance Procedures Post helpful tips, maintenance guides and R&R procedures for all Buick models here.
Closed Thread Show Printable Version Show Printable Version | Email this Page Email this Page | Subscription Subscribe to this Thread
Old 07-14-2003, 08:57 PM   #1
Flatrater
Main GM Guy
Flatrater's Avatar
1997 to 1999 Buick Regal
In the event that a transmitter is lost, program the old and the new transmitters into the memory of the remote control door lock receiver. Up to 4 transmitters may be programmed.
Important
Once entering this procedure, programming the first transmitter erases all previous transmitters. You must program all transmitters.
Program one vehicle at a time. One transmitter could be programmed into other vehicles that are also on program mode in close proximity.
1 Sit in the driver's seat.
2 Remove the ignition key from the ignition lock cylinder.
3 Close all vehicle doors.
4 Press and hold unlock on the door lock switch.
5 While holding the door lock switch in the unlock position, insert and remove the ignition key twice. Do not rotate the ignition lock cylinder.
6 Insert the ignition key a third time leaving the key in the ignition lock cylinder. The ignition must remain in the LOCK position for the rest of the procedure.
7 Release the door lock switch. You will hear three chimes. This chime feedback indicates that transmitter programming is active.
8 Press and hold the lock and unlock buttons at the same time on the keyless entry transmitter for 12 seconds. You will hear two chimes. This chime feedback indicates that the transmitter has been programmed successfully.
9 Repeat step 8 for the rest of the transmitters (for a total of 4 transmitters).
10 Exit this procedure by removing the ignition key from the ignition lock cylinder.
2000 to 2004 Buick Regal
Requires the use of a scan tool to program.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Flatrater is offline
Closed Thread
