Go Back   Automotive Forums Car Chat > Motorcycles & Choppers > Dirt Bikes
Old 03-17-2004, 11:41 AM
markbaham markbaham is offline
Question Throttle issue
I have a 125 Suzuki ATV.... When I throttle it any, it dies. But, It will idle fine. What's the deal.?
Old 03-29-2004, 11:51 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Throttle issue
The main jet in the carburetor is clogged. Its easy to fix. Remove the carburetor and carefully unscrew the float bowl. You can see the main jet. It should have a needle attached to the throttle slide that goes in and out of the main jet when you open the throttle.
Spray some carb cleaner into the main h=jet and also around the float bowl to clean out any residue.
Then reassemble.
You might want to get a service manuals so you can see instructions on how to properly remove and disassemble the carb.
Throttle Issue : 1958 VW Pickup cbbond Eurovan/Multivan/Caravelle/Transporter 1 04-02-2009 02:21 PM
1990 K1500 Throttle Issues ericmb55 C/K 3 03-21-2009 01:13 AM
2000 Impala throttle issue Crimson King Impala | Impala SS 2 06-04-2007 12:42 PM
Throttle Issue jessep28 Grand Prix 2 06-23-2006 12:14 PM
1985 Caddillac FWD Fleetwood throttle issue RickStarich General Discussion 2 01-18-2004 05:56 AM
