Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 04-23-2012, 08:49 AM
fp1529 fp1529 is offline
Fuel pump relay?
I have a 99 Suburban 1500 5.7 with 160,000 miles, original fuel pump. Yesterday the truck would not start and I realized I did not hear the fuel pump. I tried to crank it today and it fired up, I could hear the fuel pump. When the fuel pump goes is it sporadic? Could it be the pump relay?
Old 04-23-2012, 10:12 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Fuel pump relay?
Fuel pumps fail in several different ways.
When key fist turned to on you VCM sends a 2 second ground prime up signal to fuel pump relay to turn on fuel pump.
To test relay check for the key on prime up signal or engine cranking fuel pump relay ground signal.
Or some just switch out relay with a known good relay.
MT
Old 01-27-2016, 09:06 PM
stever111111 stever111111 is offline
I have a 2001 suburban. I was removing snow one night, was pulling from a garage, ran over the snow pile and it died.. Now it starts first thing in the morning (can hear fuel pump kick in) but stops after a minute or two. like turning key off (no sputtering) then it cranks with no start and no fuel pump kick in. Question: Seems to me the pump is over heating and cutting out. Is there a ground wire under chassis I could have broke loose while plowing? Can a relay get hot and short out? What can it be guys and gals?
Old 01-28-2016, 11:09 AM
j cAT j cAT is offline
being new member the best way to solve your problem is to post this as your problem by creating a new posting . your post not someones old issue. pumps do overheat from low fuel . also you have a filter. then there are wires next to the fuel tank to the frame rail. relays are not a common failure but the pump is when you run down the fuel below 1/4 tank. wires on top of the tank can be damaged like if someone replaced the 2001 pump with the new pump this requires wires to be cut and a new connector to make the connection to the new pump. well these need be soldered and sealed with heat shrink many mechanics do not do this so then it fails .
Old 01-28-2016, 11:14 AM
Thanks Cat, I'll look for the wires. The tank never gets below 1/4. Now I must learn how to start a thread
Old 01-30-2016, 11:11 AM
rhandwor rhandwor is offline
Their is a ground wire under the vehicle look on the frame near the fuel tank.
Fuel pump our relay Apfire8 Villager 1 11-10-2010 07:08 PM
Help with Fuel Pump Resister Relay bbaker1985 Grand Prix 1 03-28-2009 10:14 PM
89 Fuel Pump/Fuel Pump Relay Problem (no crank) matrx10503 Grand AM 17 03-05-2009 12:32 AM
91 escort cant locate fuel pump relay or fuel pump fuse thesandmanisme Escort 2 10-21-2008 03:38 AM
No-Start when relays clicking - fuel pump relay? 2Bonnes Bonneville 5 08-24-2008 11:34 AM
