Ac compressor air gap
Getting a whine / metal on metal noise from my ac compressor, right at the pulley. Sound goes away when ac is turned on.
From what I've read, sounds like the air gap needs to be adjusted on the pulley / clutch assembly, but I can't find a link or post that shows how to do this......any help? |
Re: Ac compressor air gap
What year Blazer? Can't see it from here- does make a difference. You can borrow the clutch puller tool from Autozone and pull the driver back to make a gap of .020".
Automotive A/C Engineer with: '99 IH 4700 Toy Hauler (2) '95 GEO Prizms both maroon '99 GMC Yukon '95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller. '94 Astro- 370k miles '94 Firebird Formula- 5.7L 180k miles- gone- '92 Chevy Lumina Van 3.8L 264k '86 GMC S-15 - 2.8L 154k '87 Buick Park Ave . 187k '86 Buick Park Ave 3.8L 199k miles- gone '77 Chevy Vega- 2.5L 175k miles gone but not forgotten '68 Camaro 396 4 spd RS/SS -72k miles- |
The gap is usually adjusted by adding or removing shims located on the compressor shaft just behind the clutch hub. They're like small washers. But its rare to have to add shims. It usually works the other way around. I would check the hub plate and springs themselves. You could have a broken hub plate spring. Turn the hub by hand,(engine off of course). See if the hub rotates evenly and the gap doesnt change. If it does theres a broken spring and you'll have to replace the hub.
Sorry DeltaP-- no shims on a Harrison compressor of that era....they are press fit if his blazer is an S/T blazer 90's to early 2000 model..we don't want to mislead OP....
Registered Offender
![]() Join Date: Mar 2006
It's a set of leaf springs. This is a common issue, easily solved by bending the leaves back unit a gap is achieved. I've done quite a handful that way. The toughest part is on wrong-wheel-drive car and getting good access to the clutch.
Thanks for the info guys.....it's a 2002 Xtreme with a 4.3 liter, automatic trans (if that makes a difference.....)
Talk about a small world, brcidd.....I lived in Troy OH from 2004 to 2007, on Woodbury Court, kind of behind Meijers! |
#7 | |
#8 | |
You need to reset your air gap. Get a proper puller tool and clean out the threads in the clutch hub and pull it out to about .020" gap, what you have if light and tinny/hissing sound is clutch drag noise. If its a deeper growl, perhaps it may be the pulley bearing.
#9 | |
Jeff
Do you have or can you provide a pic with exactly where I'm going to be measuring the 0.020"? Thanks! Booch |
#10 | |
Brcidd;
Wow; REALLY small world! I drove by your place all the time! I was at 553 Woodbury Court. Live in Minneapolis now, but really miss the small town feel of Troy! Is LaPiazza still around? |
