Old 04-15-2012, 09:02 AM
lahomer lahomer is offline
1997 3500 pickup 5.7
when the truck is under power it misses and spark knocking. whats the problem? but dose not do it all the time.
Old 04-15-2012, 11:47 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 1997 3500 pickup 5.7
Welcome to AF.
To help you with the problem we are goig to need a lot more info.
LIKE
Any check engine or flashing check engine lights or codes?
How are the plugs and wires and dist cap and fuel pressure?
Low fuel pressure and bad plugs and wires are the main cause of engine a miss.
A long with many other things.
How many miles on it and how many miles on plugs and what kind of plugs?
What is fuel pressure readings?
MT
Old 04-15-2012, 02:42 PM
the engine light is on auto zone said it was the intake air temperture sensor. when i take it to the shop they seem to be lost we put spark plugs and wires last year but didnt change the cap and rotor
Old 04-15-2012, 02:45 PM
the truck has 130,000 miles on it sometimes it rides good then all of sudden start missing and spark knocking.
Old 04-15-2012, 03:54 PM
MT-2500's Avatar
AF - Advisor
Clear code and retest.
If that code or any other code comes back repair for that code.
Confirm good fuel pressure.
Confirm and make sure you have good ac delco plugs and cap and rotor and check plug wires and good hot blue spark from coil.
Check dist shaft for side play.
If engine is missing you should be getting a code for that cylinder missing.
MT
Old 04-15-2012, 07:53 PM
j cAT j cAT is offline
post all the DTC's that are found . then we can start narrowing down where to do some testing.
air intake temp would be the MAF. I would rather have the actual codes before making recommendations.
130,ooo miles is low . could very well be bad plug wires /plugs.
Changing Intake manifold gasket 1997 chevy 350 5.7... Chillinday2day Engineering/ Technical 13 02-17-2007 12:35 AM
1997 1500 350 5.7 texasboy05 C/K 2 10-15-2006 07:40 PM
1997 Silverado 4X4 5.7 heater hose small leak wedser C/K 2 01-10-2006 11:04 AM
Correct Timing for 5.7 Vortec 1997 roadtrip120 Engineering/ Technical 5 02-16-2004 11:18 AM
