Go Back   Automotive Forums .com Car Chat > Oldsmobile > Bravada
Old 04-30-2012, 01:23 PM   #1
codyswifey1717
1999 Oldsmobile Bravada Ignition Problems
I have a 1999 oldsmobile bravada. I need help desperately. When i turn the truck off and put it into park the key does not return to the original start position it stays locked in the ignition and does not allow me to remove the key. I have made sure the truck was in park and everything else. I can restart the truck and drive down the road like there is nothing wrong... but when i shut it off put it in park and try to remove the key it does not allow me to. if any one has any clue on why this maybe let me know. thank you
codyswifey1717 is offline   Reply With Quote
Old 05-01-2012, 06:52 PM   #2
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
Re: 1999 Oldsmobile Bravada Ignition Problems
You might try wiggling the key with any key ring removed. I'd try a vertical wiggle then some wiggles with the switch not quite in the Off & ACC positions.
Chris Stewart is offline   Reply With Quote
Old 05-01-2012, 08:18 PM   #3
aleekat
Had this on a dodge ram. Shift wasn't going completely into park. Not sure on yours, mine had an adjustment under the truck near the tranny. Mine was described in Haynes repair manual.
aleekat is offline   Reply With Quote
Old 05-01-2012, 08:18 PM   #4
FishFind
One Hot Shot
it is either that your ignition switch is off a tooth or you need a new key tumbler.
Either way it is your key tumbler or ignition switch.
FishFind is offline   Reply With Quote
Old 05-01-2012, 08:19 PM   #5
FishFind
One Hot Shot
Try to take it out in "N" also.
Old 05-02-2012, 11:11 AM   #6
Tech II
Does this have a shifter on the floor?.....could be a problem with the harness to the BTSI solenoid.....not sure on Bravada's, but cars have a lock solenoid in the steering colum....if there is a harness problem, that lock solenoid does not get energized, when you put the vehicle in park, and you can't remove the key.....usually, under the column, in the area of the key, there is a plastic cover that can be removed(or just an opening), and you stick a small screwdriver upward onto a plunger....with the plunger depressed, then the key rotates all the way to be removed(should state this in the owner's manual, if you have it)....
1999 Regal LS ignition problem Bryan22 Regal 7 05-05-2012 06:21 AM
Ignition problem? Jeffstevehow Explorer | Explorer Sport Trac 1 06-22-2010 01:15 PM
1999 Jetta GLS 2.0 AEG Fuel system problem Probe '97 - '03 3 04-20-2010 11:24 PM
1999 GMC Suburban Ignition Problem petefred43060 General Discussion 2 01-19-2007 06:22 PM
1999 Olds Bravada Heater Problem thetopdoor Bravada 30 04-20-2006 09:26 PM
