Old 01-23-2004, 08:07 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
How-to: Make a 1:24 snowboard.
Well, there seemed to be some furvor over my snowboards, and I was asked repeatedly to post a how-to. It's not real hard, but I decided to go ahead and post this. You can easily modify this for a lot of stuff, skateboards, skis, simples stuff. Plus, for anyone who hasn't tried scratchbuilding, this is a real simple step-by-step that may give you some courage. Scratchbuilding isn't hard as long as you break it down into steps. Then, each small task is managable, and you only have to perfect one small step at a time.
First thing I did was do a Google search for pictures of snowboards, so I could trace one off my screen onto a peice of paper. I also found out how long the boards are, so I could figure out what scale the picture I traced was, and then scale it down. I chose to make my board 5'6" long, which is a long board, you might make yours smaller. The tips are 15" in diameter, and the middle gets down to 11" wide. That's rather narrow for the middle, but I like the way it looks. It looks more accurate than accurate looks, if you know what I mean.
There you can see the scale (ruler) I used to draw out the 1:24 snowboard (the small one on the left). If you have an architect's scale, use the 1/2 scale to draw at 1:24. (1/2"=1' at that scale, which becomes 1"=24". See?)
I put a peice of scotch tape over the snowboard, it barely fit! I traced the board's shape onto the tape to transfer it to the plastic sheet. Remember to double one edge to make it easier to remove from the paper. This will only work a couple times before the tape tears the paper you drew on.
Apply the tape with the pattern to the plastic, and cut the board shape out. The long, sweeping curves on the sides were easy to cut straight out, but the tips were not. I cut around them, slicing through the plastic until it was roughly the right size and shape, and sanded it down with my sanding block. When done, I peeled off the tape template.
To make the tips curve up, I placed a pencil over the tip, right along where the tip just starts change the direction of the curvature. I then lifted the long end of the board and bent the tip. I repeated this until I was pleased with the curvature. The curve might slowly flatten after a while, just rebend it and eventually it will stay.
Search the decals in your spares box to find interesting designs. Snowboards are a lot like skateboards, very colorful and with crazy designs. I have seen many snowboards with snowboard-product bumper stickers, so I found some stickers off an old NASCAR decal set to use. I used ones that weren't obviously car related, and sounded funny or maybe applicable to boards. Aeroquip, Moog, Stant on the Red Line board (from the Red Line Oil NASCAR decal) for example. I got the eyeball out of a Revell RatRod kit. After some thought, I figured aircraft nose art could be really cool for this application.
The bindings aren't that hard, actually, I made them with thin plastic. There are six parts, the foot, the ankle and the two sides. Check the picture. The foot is 3/16" wide, and 3/8" long, sanded to a curved toe. The ankle support is 1/4" wide and 3/8" long. The sides are cut to fit. Fold them up, glue them, and you've got it. The other two parts are the straps, which I made from thin styrene strip. To make that task easier, bend the strip before gluing it. Make sure the glue is set before doing the other side. Paint the bindings using what you might find in a Google search as reference. They seem to usually be dark colors, with a lighter contrasting color for the padding inside (or whatever it is) and then silver on the buckles. Once painted, glue them to the board. They are about 20" (scale) apart, or the outside edges will be just under an inch apart. The leading foot should be angled a few degrees. Leading with the right foot is goofy-foot, in case you don't know (I didn't) so place the bindings as you wish. I did one of each since I had two.
You're done. Get a roof rack and put them on top of a car. Or, if you have a big back seat, throw them in the back. My bindings aren't the best, I'm sure someone else could make them better, but this is a pretty simple way to make a snowboard. It looks rather convincing, too, if I may say so myself.
Thanks for looking.
The Following User Says Thank You to willimo For This Useful Post:
tonioseven (03-13-2012)
Old 01-23-2004, 08:22 PM
sweetwhiteCAV sweetwhiteCAV is offline
Send a message via AIM to sweetwhiteCAV Send a message via Yahoo to sweetwhiteCAV
Re: How-to: Make a 1:24 snowboard.
wow, very cool idea. im gonna have to try it....
Old 01-23-2004, 10:51 PM
Zcaithaca's Avatar
Zcaithaca Zcaithaca is offline
fershizzle
Send a message via AIM to Zcaithaca
awesome tutorial...pretty realistic too!!
Zach
Old 01-23-2004, 11:00 PM
Oddpac87's Avatar
Oddpac87 Oddpac87 is offline
awesome
They look great, you should do a roof-rack tutorial too.
Old 01-23-2004, 11:44 PM
TireGaint TireGaint is offline
Thanks.
Old 01-24-2004, 02:17 PM
pettercardoso's Avatar
pettercardoso pettercardoso is offline
Send a message via MSN to pettercardoso
Great how-to!
Hey Jay! is this in the how-to section already?
Pedro
Click the picture to check my progress thread:
Old 01-24-2004, 05:07 PM
chrismcgee's Avatar
chrismcgee chrismcgee is offline
WWW.ELITESCALECARS.CO.UK
very cool! i like them a lot!
i was going to try and make a mini surf board but just cant seem to get the energy to try and shape it so i can put it into my coverted Scooby doo van!
but i now think that i may convert it into a ski van filled with snowboards. cheers for the how to!
Old 01-24-2004, 05:25 PM
Jay! Jay! is offline
Horizontally Opposed
Re: Re: How-to: Make a 1:24 snowboard.
Originally Posted by pettercardoso
Great how-to!
ummm... yes... turns out it was...
Thanks for the write up, Will!
Hierarchy of Subaru:
(Click to see mine!)
Old 01-24-2004, 06:56 PM
Genius!
Old 03-08-2005, 03:54 AM
Ran's Avatar
Ran Ran is offline
Good tutorial!
Ran
Please read the AF guidelines
if you haven't read them before.
Old 03-08-2005, 04:03 AM
tardster tardster is offline
Nice.....
Old 03-11-2012, 01:04 PM
intuned's Avatar
intuned intuned is offline
any ways i can see the pictures since the thread is very old?
i want to build one but i have no reference pics of a scaled one
HOW TO: Make Your Car Go Faster KustmAce Performance 33 12-13-2010 07:32 AM
HOW TO: Make Subframe Connectors CamaroSSBoy346 Car Modeling 4 07-26-2004 04:37 PM
HOW TO: making "smoke" affect in windows Zcaithaca Car Modeling 10 12-03-2003 09:44 PM
HOW TO: Make Covers for your truck beds CamaroSSBoy346 Car Modeling 13 11-18-2003 04:25 PM
How to: Make deepdish rims Dr.AK Graphic Manipulation 9 07-10-2003 01:23 PM
