Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 09-03-2011, 05:14 PM   #1
cumin12_valve
99 neon no fire
ok i have read and followed all the no start issue threads, i have a 1999 sohc
neon! i put new headgasket, timing belt, water pump, it started up and ran great!! then i drove about 5 miles, pulled in to driveway and shut car off!! it hasnt ran since!! no spark! i replaced coil, cam sensor, crank sensor, and ecm! no spark untill i release the ignition key and then all plugs will fire at same time..... i even hot wired the ignition switch to rule it out!! any suggestions would be great!!! and yes i pulled and checked the wireing harness and nothing broke or shorted!!
cumin12_valve is offline   Reply With Quote
Old 10-30-2011, 07:53 PM   #2
Daniel in Detroit
Re: 99 neon no fire
I would check the fuel pump. Try hearing the pump energize when you turn on the key and see if you hear it.
Daniel in Detroit is offline   Reply With Quote
Chrysler Cirrus who have caught in fire serge_saati General Discussion 3 11-15-2010 09:45 AM
95 Neon firing problem PremiumSaltine Neon | Plymouth Neon 5 07-06-2010 08:32 PM
mysterious wire and won't fire dragontrlr Ram Van 60 02-12-2010 03:16 PM
90 Accord LX - No Fire this morning CheapRudy Accord/TSX/Accord Hybrid 3 10-24-2009 05:22 PM
88 Sundance firing problems, won't run sundancer General Discussion 0 09-06-2009 12:02 PM
