Go Back   Automotive Forums .com Car Chat > Ford > Taurus | Taurus Wagon
Old 10-04-2011, 07:02 PM   #1
aluminuman
Got the shakes at stoplights! Diagnosis?
Hi all,
I'm hoping to get a little help diagnosing a problem with my '95 Taurus V6 3.0L. Here's the scoop:
When I'm sitting at a stoplight, my car shakes. When I begin to accelerate again, the shaking stops. Also, if I put it in park, the shaking stops. The problem only persists while I'm stopped AND in gear. Any thoughts?
Thanks so much
aluminuman is offline   Reply With Quote
Old 10-04-2011, 11:48 PM   #2
shorod
SHO No Mo
shorod's Avatar
Re: Got the shakes at stoplights! Diagnosis?
Welcome to the forum!
Sounds like a misfire, either ignition or due to a vacuum leak. Do you know the last time a tune up was performed on the car? I'd suggest starting by carefully inspecting all vacuum hoses for cracks or splits, inspect the intake air tubing for cracks and to make sure it is properly secured at both ends, then change the spark plugs, spark plug wires, air filter, fuel filter, distributor cap and rotor (if your engine is one that had a cap and rotor).
-Rod
Old 10-13-2011, 04:31 PM   #3
taurusffv
Sounds like my recent problem. The car bounced and surged and bucked like a horse at stoplights. The rpm needle would bounce. Accelerating in the slightest would release the problem-no problems while driving short or long distances The longer it went on the worse it got till eventually the car would stall if the red light was too long. Shifting into park at every red light and revving got old. I took it to repair 2wks ago. I had a hose that was cut, possibly during the previous structural repair of springs struts rods etc. They replaced the hose and all is good again. Total bill guessing just under $200 (I had other repairs done on windshield washer reservoir and an air sensor fix I didnt ask for-go figure, the light went back on a wk later.)
taurusffv is offline   Reply With Quote
steering wheel shaking, pulling to the right uspres2020 Escort 6 10-10-2009 06:58 PM
66 Nova's got the shakes Rroxon7 Nova 1 08-18-2006 12:20 PM
i need the code for my radio i changed my battery and got screwed i got the serial nu sam jaludi 3000GT/Stealth 3 04-12-2005 07:29 PM
Engines Got The Shakes... golmsted Durango 1 03-14-2004 11:57 AM
