Old 05-04-2011, 12:34 PM   #1
avieitan
Engine measurements|I need help
I know that I have to do three tests
1. Biggest degree of wear - I reset the dail indicator. take attention where it stops, taking the indicator to micrometer and that how I checks how much I need to hone the cylinder
2. Connie difference
- lowers the indicator up to 5 mm from the end of the cylinder (swinging) move left and right and what is the indicator dial 0 to where it stopped and making note
3. Oval difference - here I become involved
, someone told me I had to take the indicator on the point you've reset the indicator , rotate the indicator 90 degrees from there. Take this measure without ' swinging' left and right the indicator. I thought that i need to
' swinging' .
Someone please help me?
avieitan is offline   Reply With Quote
Old 05-05-2011, 06:28 PM   #2
534BC
Re: Engine measurements|I need help
It sounds like you are describing how to measure cylinder bores with a dial bore gage. You pretty much have it correct.
The bore gage must always be read at the largest reading whether you rock it back and forth or not. If it is kept parallel with the cylinder it isn't necessary to rock it back and forth.
The cylinder must be checked at all points , but experience and practise will show you where the largest part is always. Most times it is just where the top piston ring stops perpendicular to the crankshaft.
I don't prefer or recommend this way ", someone told me I had to take the indicator on the point you've reset the indicator , rotate the indicator 90 degrees from there. Take this measure without ' swinging' left and right the indicator. I thought that i need to
' swinging' ." You may not get a good reading since bore gages are not designed to be rotated. You can rotate first then swing back and forth though.
I hope this helps you. I have trouble with your english a little bit.
534BC is offline   Reply With Quote
I need help A.S.A.P with my engine jstevens1978 General Discussion 3 07-21-2009 03:54 PM
engine light on!!! NEED HELP jetta3gl Jetta/Vento/Bora 8 04-09-2004 11:04 PM
Coolant Loss/ Engine Torn Down NEED HELP ASAP estone4009 C/K 1 03-30-2004 08:32 AM
1997 Service engine soon light, need help afelix9137 Blazer 4 03-22-2004 01:21 PM
engine messed up, need help tph1207 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 11 02-05-2003 08:02 PM
