Old 04-06-2011, 02:56 AM
carpenter_jai's Avatar
carpenter_jai carpenter_jai is offline
AF Stunt Driver
Custom Canopy Build
Hey there,
I want to share how I made a canopy for my truck to best suit my desire to see out the back window and have plenty of covered storage. I built this out of 5/8" fir plywood select grade. The ribs are 2x2 spf lumber. The joints are glued and pin (brad) nailed. it probably weighs 50 lbs I'd guess. I used a "piano" hinge, which is getting a bit rusty.
Driving at speeds up to 120 km/h (I didn't test faster)there is no movement or wandering. The lid fits in place quite well. I am happy with the design and will stain it black most likely and seal it. I will attach strap tie downs and locking/latching mechanisms. (These only for security sake). I also would like to find long gas/air pistons so that the hatch can be opened without crawling into the bed. I will take some better pictures of the inside and post them.
Can someone suggest ideas for locking it up. I will be opening and closing the tailgate and canopy a lot, so I want to have a smart locking system.
Thanks for any advice,
Jai
http://img7.imageshack.us/i/p1010167u.jpg/
http://img833.imageshack.us/i/p1010212d.jpg/
http://img163.imageshack.us/i/p1010218d.jpg/
Uploaded with ImageShack.us
96 3 cylinder Geo Metro (currently being rebuilt)
Old 04-08-2011, 01:32 AM
AF Stunt Driver
Re: Custom Canopy Build
Old 04-08-2011, 02:59 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Nice job..
Some lift supports would really make it custom.
http://www.oreillyauto.com/site/c/de...ord=hood+shock
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 04-08-2011, 08:44 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
The best thing I can think of is a latch/lock just like a cap has. When you twist the handle, it extends two rods out to each side. Yours would have the rods tuck under something to prevent lifting instead of behind something to prevent pulling like a cap, but it should be pretty easy to design/install. I doubt they're cheap though.
Another idea would be to use two smaller versions of the same thing - instead of one central handle with rods, you have one on each side that just swings a tab behind the latch.
Dragging people kicking and screaming into the enlightenment.
Custom Camaro 1969 EtienneArt Sketching and Drawing 0 01-08-2010 12:55 PM
Custom fridge magnets, car magnets, business card magnets- Australia fridgemagnet Graphic Manipulation 0 03-09-2009 02:20 AM
error or trouble codes 93 buick lesabre custom thecone_99 LeSabre 9 03-03-2009 07:49 AM
Custom turbo build 808drifter Eclipse 2000+ 4 09-11-2006 03:49 PM
