TPS or IAC?
Hi All,
Got an '87 GM that has a "slight up/down idle" when first starting. Only lasts a minute or so and then is fine. Sometimes a slight stumble from a stop. Likeliness culprit be a TPS or IAC?? Car has a little over 121K and have had it from brand new. Never remember changing the TPS but did the IAC a couple of years ago. Forgot to clean out the ports before install, though. Boy was that dumb!! Let me know your thoughts!! Thanks....MB |
Re: TPS or IAC?
Use a multimeter to check the resistance of the TPS as you move it.
It could also be a fuel pressure problem.
![]() 2000 Mercury Grand Marquis LS - 119k / 14.89s @ 92.11MPH [ pictures | videos ] > Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok > Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB > BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms > CVPI aluminum driveshaft |
TOKEN HILLBILLY
![]() Join Date: Mar 2005
Re: TPS or IAC?
There is an Intake Air Temperature sensor on the drivers side front that will cause the problem you describe.
Being way2old is why I need help from younger minds The sooner you fall behind the more time you'll have to catch up. ![]() HEY Y'ALL--READ THIS Here are some of our old vehicles for sale.
Re: TPS or IAC?
Where exactly is that sensor located? Looks like it is threated into something and has an electrical connector but where is it screwed into? Thanks....MB
Re: TPS or IAC?
Not sure about on a 5.0L, but on my 4.6L it was located on the top half of the air filter box.
Re: TPS or IAC?
Yes, I had a '93 and also currently have a '95 and on the 4.6L, that is where it is. Didn't even know a 5.0 has one? Got to check the official manual as Rock Auto does list one for the 5.0.....MB
#7 | |
TOKEN HILLBILLY
Re: TPS or IAC?
Look on the intake between 5 and 6 cylinders. it should be licated there if I remember correctly.
#8 | |
Re: TPS or IAC?
Hey Good Buddy! Is that Passenger or Driver's side?? MB
#9 | |
TOKEN HILLBILLY
Re: TPS or IAC?
Drivers side. Those little sensors are suspect to carbon build up on them.
