![]() Join Date: Jun 2007
today at work my car started doing this. what its doing is making the sound of the signal light at a rly high rate of speed when its not on but when i go to turn it on left or right it makes the normal pace sound. same as when ive turned on my foreways. i also figured out that if i push my foreway button about a qautar to half way in the noise stopes totaly.
any help would be handy |
Re: 2001 grand am signal lights
I have this same issue issue in my mother in laws 04 grand am gt....any ideas anyone? I figure it would be either the relay or the multifunction switch.
2004 GRAND PRIX GTP COMP G. VIN 4 : OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST. 2004 Honda Odyssey EX-L
your multifunction switch (the arms) on the steering is dirty.
I fixed mine by removing it and spraying a generous amount of contact cleaner inside. If you remove it, beware of the airbag wire, and the horn pin when you put it back in. |
yeah that was the problem, I cleaned it and it worked. I did a search and found other threads that said to clean it before replacing it.
out saving the world
![]() Join Date: Jul 2005
something with the grand am in specifics is the hazard relays, connected to the button/switch, were prone to going out w/factory relays.
Replacements dont do this.
1999 Grand Am SS 3.4 OHV
