Go Back   Automotive Forums .com Car Chat > Toyota > Corolla/Matrix/Voltz
Old 10-15-2010, 09:36 AM   #1
samthecarman
2007 Corolla engine compartment vibration/knocking
Hi all, I am having some trouble diagnosing a particular problem with my Corolla
There is a constant knocking noise that starts out soft and gradually gets louder coming from the left side of the engine compartment. It only happens when sitting still with the car in drive. As soon as I put the car in neutral or reverse the sound goes away. It usually happens when it is cool out/car is just started up, but it is has occurred in warmer conditions. I did a quick check of the engine compartment to check for loose/broken engine mounts, components, etc... but found nothing. Thanks in advance.
samthecarman is offline   Reply With Quote
Old 10-27-2010, 02:07 AM   #2
Feint Motion
Feint Motion's Avatar
Re: 2007 Corolla engine compartment vibration/knocking
Check your Air box, that tends to vibrate.
~Josh~
OldUser:IImportSupra
Do You Have a Car that Goez Sideways?
Feint Motion is offline   Reply With Quote
Old 12-31-2010, 10:28 PM   #3
samthecarman
You were right it was the air box. Added 1 washer to the mounting bolts and the noise went away.
Engine Conversion Jezzaa Corolla/Matrix/Voltz 0 12-18-2009 11:27 PM
Vibration/buzz from engine compartment dcleckler Tracker 4 01-24-2006 08:57 PM
Corolla Engine Vibrates and Sputters at Idle dwilliams141 Corolla/Matrix/Voltz 2 03-28-2005 10:41 PM
2002 Corolla / Engine Vibrations Origen Corolla/Matrix/Voltz 1 01-11-2005 08:53 AM
