After I start my car I hear a howling noise. The sound doesn't increase or decrease when I press or depress the gas pedal. Inside the car it sounds like it's coming from under my back seat. When I go outside and listen underneath it is louder of course but coming from that same general area. No codes on the meter.
Could it be my fuel pump fixing to go out??? |
Lactose the Intolerant
![]() Join Date: Aug 2004
Re: Strange noise
Sounds like.
| The Following User Says Thank You to jeffcoslacker For This Useful Post: |
bsr2002 (03-26-2011)
Re: Strange noise
you could listen with the engine off.have someone turn key to on
you only have a few seconds before pump shuts down but that will comfirm if its the pump
Live For Today Yesterday is gone, Tomorrows are'nt promised. |
| The Following User Says Thank You to inafogg For This Useful Post: |
Re: Strange noise
Re: Strange noise
no,i was just saying to listen w/engine off so you could verify
that it is or is'nt the pump making the noise your hearing if it is the pump(like you think)is it ready to quit? not really you can check the pressure.pumps usually start to loose pressure gradually, rare to just stop but is possible & have seen.nomal to have estended crank or hard start when going bad. hope this answers your ?? Good luck
#6 | ||
Re: Strange noise
I will check the pressure, where is the test port for the fuel pressure located? |
#7 | |
Re: Strange noise
if you look from r/f passenger fender the end of the fuel rail,the screw
cap will be pointed towards you. took me awhile to find first time i looked on mine(96 3.1) Good luck
#8 | |
Re: Strange noise
#9 | ||
Re: Strange noise
